Saltar al contenido principal
Philips Sonicare 2 Series Disassembly
Sólo Prerrequisito
Esta guía solo debería usarse como prerrequisito para otras guías. Por tanto, estará incompleta.
Qué necesitas
  1. Philips Sonicare 2 Series Disassembly, Philips Sonicare 2 Series Disassembly: paso 1, imagen 1 de 1
    • Pull upwards to remove the brush head from the top of the device.
  2. Philips Sonicare 2 Series Disassembly: paso 2, imagen 1 de 1
    • Remove the 12 mm T8 Torx screw from the bottom of the toothbrush. After removing the screw, pry off the base with a plastic opening tool.
  3. Philips Sonicare 2 Series Disassembly: paso 3, imagen 1 de 2 Philips Sonicare 2 Series Disassembly: paso 3, imagen 2 de 2
    • Remove the internal electronic mechanism from the housing by prying the red clips shown in the figure. This removes the charging port.
    • Be very careful not to damage the charging port during this step. Otherwise you will have to solder this part back to the device as shown in the second figure.
  4. Philips Sonicare 2 Series Disassembly: paso 4, imagen 1 de 1
    • Next you will be able to remove the internal electronic mechanism as shown in the figure.
  5. Philips Sonicare 2 Series Disassembly: paso 5, imagen 1 de 1
    • Remove the white battery cover as shown in the figure.
  6. Philips Sonicare 2 Series Disassembly: paso 6, imagen 1 de 1
    • Remove the white circuit board cover as shown. This cover will require you to pry off the piece from the groves .
Conclusión
Equipo
IUPUI, Team S6-G2, Baechle Fall 2017 Miembro de IUPUI, Team S6-G2, Baechle Fall 2017
IUPUI-BAECHLE-F17S6G2
3 Miembros
8 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 3
Todo El Tiempo: 92
