Saltar al contenido principal
Philips Satinelle Plastic Cover Replacement
Qué necesitas
  1. Philips Satinelle Plastic Cover Replacement, Plastic Cover: paso 1, imagen 1 de 3 Philips Satinelle Plastic Cover Replacement, Plastic Cover: paso 1, imagen 2 de 3 Philips Satinelle Plastic Cover Replacement, Plastic Cover: paso 1, imagen 3 de 3
    • Remove the head by pushing it to the right.
  2. Philips Satinelle Plastic Cover Replacement: paso 2, imagen 1 de 2 Philips Satinelle Plastic Cover Replacement: paso 2, imagen 2 de 2
    • Use a metal spudger to pry open the casing.
    • Caution: The epilator's internal components could be damaged if you shove the spudger in too far.
  3. Philips Satinelle Plastic Cover Replacement: paso 3, imagen 1 de 1
    • Pull the plastic casing apart with your hands.
    • The plastic tab connecting the cover is likely going to break when you pull the device apart. This will not affect the operation of the epilator.
Conclusión
To reassemble your device, move the components from the broken shell into the new shell and follow these instructions in reverse order.
Equipo
Marist, Team S1-G1, Chaterdon Fall 2018 Miembro de Marist, Team S1-G1, Chaterdon Fall 2018
MARS-CHATERDON-F18S1G1
3 Miembros
4 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 16
Todo El Tiempo: 574
