Saltar al contenido principal
Philips Respironics V60 Touchscreen Replacement
Equipo médico
El fabricante de este equipo médico no ha avalado o contratado a iFixit ni a esta guía de reparación.
  1. Philips Respironics V60 Touchscreen Replacement, Touchscreen: paso 1, imagen 1 de 1
    • From the Diagnostics Menu, select Touch Screen Calibration. The Calibrate Touch Screen screen is displayed.
    • Follow the steps shown. Press on the middle of each target with a blunt, narrow object.
    • NOTE: If the Touch Screen Calibration button does not respond, press the Accept button on the navigation ring to begin
    • If the calibration is not successful, have the ventilator serviced.
  2. Philips Respironics V60 Touchscreen Replacement: paso 2, imagen 1 de 1
    • Press and release the ON/Shutdown key, opening the Shutdown window in the screen.
    • Select Ventilator Shutdown, which will shut down the ventilator.
    • Improper shutdown may cause a Power has been restored message the next time the ventilator is turned on.
  3. Philips Respironics V60 Touchscreen Replacement: paso 3, imagen 1 de 1
    • Remove the screws from the end cap and remove the end cap.
    • Remove the screws from the rear bezel.
    • Separate the front and rear bezel.
  4. Philips Respironics V60 Touchscreen Replacement: paso 4, imagen 1 de 1
    • Disconnect these cables from the UI PCBA: • Switch PCBA cable • Nav-ring cable • Power switch overlay cable • Touch screen cable
    • Remove the switch PCBA.
    • Remove the screw that attaches the cable clamp to the LCD tray.
    • Remove the screws and washers that attach the LCD tray to the front bezel, then remove the LCD tray.
    • Remove the touch screen from the front bezel.
Conclusión
Weihan Du
Miembro Desde 04/11/20
241 Reputación
2 Guías creadas
Equipo
Cal Poly, Team S7-G10, Paton Spring 2020 Miembro de Cal Poly, Team S7-G10, Paton Spring 2020
CPSU-PATON-S20S7G10
2 Miembros
9 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 14
Ultimos 30 días: 40
Todo El Tiempo: 2,034
