Saltar al contenido principal
Philips Pressurised Steam Generator Iron GC8220 and Similar Models' Temperature Sensor (NTC Thermistor) Replacement
  1. Philips Pressurised Steam Generator Iron GC8220 and Similar Models' Temperature Sensor (NTC Thermistor) Replacement, Temperature Sensor (NTC Thermistor): paso 1, imagen 1 de 1
    • The Temperature Sensor is attached to the bottom of the Boiler unit.
    • It is an NTC Thermistor.
  2. Philips Pressurised Steam Generator Iron GC8220 and Similar Models' Temperature Sensor (NTC Thermistor) Replacement: paso 2, imagen 1 de 1
    • It is connected to the Main PCB.
  3. Philips Pressurised Steam Generator Iron GC8220 and Similar Models' Temperature Sensor (NTC Thermistor) Replacement: paso 3, imagen 1 de 1
    • It looks like a diode. But it is a resistor that changes value with temperature.
  4. Philips Pressurised Steam Generator Iron GC8220 and Similar Models' Temperature Sensor (NTC Thermistor) Replacement: paso 4, imagen 1 de 1
    • They come in a range of values. 10kOhms ~ 100 kOhms.
Conclusión
4 personas más completaron esta guía.
Omid
Miembro Desde 07/23/17
228 Reputación
1 Guía escrita
5 comentarios
With GC9640 the termistor is 226 kOhm @ 26°C.
Beim GC9640 hat der NTC 226 kOhm bei 26°C
John Maier - Contestar
My Philips GC 9245 after ironing found water on the shirts, and the iron heat is not like as hot as in the past, is this cause by the Temperature Sensor (NTC Thermistor) ?
lylim_ly - Contestar
With GC9220 model, résistance of boiler CTN : around 300k à 15°C, decreasing slowly to 160K at around 30°C, I didn’t test with other temperature.
Nico Land - Contestar
Hi all , Does anyone know how much should be the resistance on ohm of the boiler of Philips iron steamer GC9241.Thanks
Nikos Sapranidis - Contestar
Hi, my philips gc7808 do not heating up and no steam come out after beep sound after 2 mins switch on. Checked the thermaster using multimeter on continuity. Its ok. Is it possibility that temperature sensor ntc is not working hence my iron not heating up
mohd zuki - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 32
Ultimos 30 días: 94
Todo El Tiempo: 6,531
