Introducción
Use this guide to replace the battery of your Philips Norelco 2100 as it may be defective.
Qué necesitas
Remove the clear case that holds the circuit board by lifting the latches on the sides and then pulling gently.
11 personas más completaron esta guía.
14 comentarios
To remove the battery you have to actually desolder both ends from the chip.
What are the dimensions/specs of the battery?
The tricky part is taking the case appart. You have to gently pry on tabs to get it appart. You may break some pieces which probably won’t be a problem. May make it no longer waterproof. The battery is custom but is close to a 14450 Lion battery, do searches on ebay and aliexpress you will find them. Good luck.
