Saltar al contenido principal
Philips Norelco OneBlade Exterior Casing Replacement
Qué necesitas
  1. Philips Norelco OneBlade Exterior Casing Replacement, Exterior Casing: paso 1, imagen 1 de 3 Philips Norelco OneBlade Exterior Casing Replacement, Exterior Casing: paso 1, imagen 2 de 3 Philips Norelco OneBlade Exterior Casing Replacement, Exterior Casing: paso 1, imagen 3 de 3
    • Ensure razor is off, and razor blade has been removed.
  2. Philips Norelco OneBlade Exterior Casing Replacement: paso 2, imagen 1 de 2 Philips Norelco OneBlade Exterior Casing Replacement: paso 2, imagen 2 de 2
    • Locate crease in bottom third of razor.
    • Hold razor in both hands, and place thumbs near crease.
    • Slightly bend the razor near crease.
    • Pull top razor apart.
    • Caution, device may turn on upon removal. Turn off razor before continuing.
  3. Philips Norelco OneBlade Exterior Casing Replacement: paso 3, imagen 1 de 1
    • Power button should face forward in same direction as circuit board. The crease on each casing component should line up.
Conclusión
Please dispose of exterior casing properly. For recycling information, please contact your local waste management facilities or visit www.recycle.philips.com
Joshua Etchberger
Miembro Desde 11/07/17
472 Reputación
3 Guías creadas
Equipo
IUPUI, Team S3-G3, Harley Fall 2017 Miembro de IUPUI, Team S3-G3, Harley Fall 2017
IUPUI-HARLEY-F17S3G3
3 Miembros
3 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 9
Ultimos 30 días: 32
Todo El Tiempo: 3,028
