Saltar al contenido principal
Philips Norelco BeardTrimmer 3100 Zoom Lock Precision Notch Replacement
Qué necesitas
  1. Philips Norelco BeardTrimmer 3100 Zoom Lock Precision Notch Replacement, Front and Back Panels: paso 1, imagen 1 de 1
    • Remove the comb from the top of the trimmer.
  2. Philips Norelco BeardTrimmer 3100 Zoom Lock Precision Notch Replacement: paso 2, imagen 1 de 2 Philips Norelco BeardTrimmer 3100 Zoom Lock Precision Notch Replacement: paso 2, imagen 2 de 2
    • Place your thumb underneath the blade and push upward to remove it.
  3. Philips Norelco BeardTrimmer 3100 Zoom Lock Precision Notch Replacement: paso 3, imagen 1 de 2 Philips Norelco BeardTrimmer 3100 Zoom Lock Precision Notch Replacement: paso 3, imagen 2 de 2
    • Hold trimmer towards you as shown in the diagram.
    • Insert your prying tool/metal spudger into the marked area.
  4. Philips Norelco BeardTrimmer 3100 Zoom Lock Precision Notch Replacement: paso 4, imagen 1 de 3 Philips Norelco BeardTrimmer 3100 Zoom Lock Precision Notch Replacement: paso 4, imagen 2 de 3 Philips Norelco BeardTrimmer 3100 Zoom Lock Precision Notch Replacement: paso 4, imagen 3 de 3
    • Apply gentle pressure and begin prying open the back panel.
    • Separate the panel one notch at a time. Listen carefully as you're prying the panel apart and notice each individual notch release.
  5. Philips Norelco BeardTrimmer 3100 Zoom Lock Precision Notch Replacement: paso 5, imagen 1 de 3 Philips Norelco BeardTrimmer 3100 Zoom Lock Precision Notch Replacement: paso 5, imagen 2 de 3 Philips Norelco BeardTrimmer 3100 Zoom Lock Precision Notch Replacement: paso 5, imagen 3 de 3
    • Pull the trimmer apart using your hands once the panel is at least halfway apart.
    • Pull the wires attached to the battery off of the power connectors before completely removing the back panel.
  6. Philips Norelco BeardTrimmer 3100 Zoom Lock Precision Notch Replacement: paso 6, imagen 1 de 2 Philips Norelco BeardTrimmer 3100 Zoom Lock Precision Notch Replacement: paso 6, imagen 2 de 2
    • Hold the trimmer towards you.
    • Place the metal spudger tool in the marked area.
  7. Philips Norelco BeardTrimmer 3100 Zoom Lock Precision Notch Replacement: paso 7, imagen 1 de 1
    • Apply gentle pressure and begin prying the front panel.
    • Separate the front panel one notch at a time.
  8. Philips Norelco BeardTrimmer 3100 Zoom Lock Precision Notch Replacement: paso 8, imagen 1 de 2 Philips Norelco BeardTrimmer 3100 Zoom Lock Precision Notch Replacement: paso 8, imagen 2 de 2
  9. Philips Norelco BeardTrimmer 3100 Zoom Lock Precision Notch Replacement, Zoom Lock Precision Notch: paso 9, imagen 1 de 1
    • Locate the zoom lock precision notch in the back panel of the Beardtrimmer
  10. Philips Norelco BeardTrimmer 3100 Zoom Lock Precision Notch Replacement: paso 10, imagen 1 de 1
    • Set the zoom lock wheel to the lowest setting
  11. Philips Norelco BeardTrimmer 3100 Zoom Lock Precision Notch Replacement: paso 11, imagen 1 de 2 Philips Norelco BeardTrimmer 3100 Zoom Lock Precision Notch Replacement: paso 11, imagen 2 de 2
    • Rotate the trimmer so that the motor is facing you.
    • Now gently push down the zoom lock wheel until the white button is not showing.
  12. Philips Norelco BeardTrimmer 3100 Zoom Lock Precision Notch Replacement: paso 12, imagen 1 de 3 Philips Norelco BeardTrimmer 3100 Zoom Lock Precision Notch Replacement: paso 12, imagen 2 de 3 Philips Norelco BeardTrimmer 3100 Zoom Lock Precision Notch Replacement: paso 12, imagen 3 de 3
    • Rotate the beardtrimmer again so that the battery is facing you.
    • With the help of the metal spudger, apply gentle pressure on top of the wheel to remove the zoom lock precision notch .
Conclusión
ilan
Miembro Desde 09/03/15
173 Reputación
1 Guía escrita
Equipo
USF Tampa, Team 15-2, Blackwell Fall 2015 Miembro de USF Tampa, Team 15-2, Blackwell Fall 2015
USFT-BLACKWELL-F15S15G2
4 Miembros
8 Guías creadas
Un comentario
How to fix charging wire to the plate?
Kartik Gusain - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 20
Todo El Tiempo: 4,440
