Saltar al contenido principal
Philips Norelco BeardTrimmer 3100 Battery Replacement
Qué necesitas
  1. Philips Norelco BeardTrimmer 3100 Battery Replacement, Front and Back Panels: paso 1, imagen 1 de 1
    • Remove the comb from the top of the trimmer.
  2. Philips Norelco BeardTrimmer 3100 Battery Replacement: paso 2, imagen 1 de 2 Philips Norelco BeardTrimmer 3100 Battery Replacement: paso 2, imagen 2 de 2
    • Place your thumb underneath the blade and push upward to remove it.
  3. Philips Norelco BeardTrimmer 3100 Battery Replacement: paso 3, imagen 1 de 2 Philips Norelco BeardTrimmer 3100 Battery Replacement: paso 3, imagen 2 de 2
    • Hold trimmer towards you as shown in the diagram.
    • Insert your prying tool/metal spudger into the marked area.
  4. Philips Norelco BeardTrimmer 3100 Battery Replacement: paso 4, imagen 1 de 3 Philips Norelco BeardTrimmer 3100 Battery Replacement: paso 4, imagen 2 de 3 Philips Norelco BeardTrimmer 3100 Battery Replacement: paso 4, imagen 3 de 3
    • Apply gentle pressure and begin prying open the back panel.
    • Separate the panel one notch at a time. Listen carefully as you're prying the panel apart and notice each individual notch release.
  5. Philips Norelco BeardTrimmer 3100 Battery Replacement: paso 5, imagen 1 de 3 Philips Norelco BeardTrimmer 3100 Battery Replacement: paso 5, imagen 2 de 3 Philips Norelco BeardTrimmer 3100 Battery Replacement: paso 5, imagen 3 de 3
    • Pull the trimmer apart using your hands once the panel is at least halfway apart.
    • Pull the wires attached to the battery off of the power connectors before completely removing the back panel.
  6. Philips Norelco BeardTrimmer 3100 Battery Replacement: paso 6, imagen 1 de 2 Philips Norelco BeardTrimmer 3100 Battery Replacement: paso 6, imagen 2 de 2
    • Hold the trimmer towards you.
    • Place the metal spudger tool in the marked area.
  7. Philips Norelco BeardTrimmer 3100 Battery Replacement: paso 7, imagen 1 de 1
    • Apply gentle pressure and begin prying the front panel.
    • Separate the front panel one notch at a time.
  8. Philips Norelco BeardTrimmer 3100 Battery Replacement: paso 8, imagen 1 de 2 Philips Norelco BeardTrimmer 3100 Battery Replacement: paso 8, imagen 2 de 2
  9. Philips Norelco BeardTrimmer 3100 Battery Replacement, Battery: paso 9, imagen 1 de 3 Philips Norelco BeardTrimmer 3100 Battery Replacement, Battery: paso 9, imagen 2 de 3 Philips Norelco BeardTrimmer 3100 Battery Replacement, Battery: paso 9, imagen 3 de 3
    • Face the battery towards you.
    • Locate the power connectors on the bottom of the trimmer, pull them from the base with your spudger.
  10. Philips Norelco BeardTrimmer 3100 Battery Replacement: paso 10, imagen 1 de 1
    • Grab the battery by its sides, pull it upwards out of the base of the trimmer.
  11. Philips Norelco BeardTrimmer 3100 Battery Replacement: paso 11, imagen 1 de 2 Philips Norelco BeardTrimmer 3100 Battery Replacement: paso 11, imagen 2 de 2
    • Locate the connection between the blue wire and the battery. Melt the solder and completely remove the battery.
    • Be careful when dealing with solder. The metals will become very hot and can cause damage to skin/clothing.
Conclusión
29 personas más completaron esta guía.
Darren Chu
Miembro Desde 09/03/15
1,605 Reputación
3 Guías creadas
Equipo
USF Tampa, Team 15-2, Blackwell Fall 2015 Miembro de USF Tampa, Team 15-2, Blackwell Fall 2015
USFT-BLACKWELL-F15S15G2
4 Miembros
8 Guías creadas
20 comentarios
Hi, what are the specs on the NiMh battery?
Eric Nguyen - Contestar
NiMh AA 1650 mAh 1.2V rechargeable battery. Search Amazon.com for philips norelco qt4022 battery. One result is UPC 737212062822
galligant -
I think you can simply use a AA battery, 1.2V
Olivier Lefaux - Contestar
Note: AA Alkaline battery is 1.5V and not rechargeable.
galligant -
Awesome work.very helpful
Himanshu sahrma - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 5
Ultimos 7 días: 40
Ultimos 30 días: 223
Todo El Tiempo: 70,961
