Saltar al contenido principal
Philips Norelco BG2040 BodyGroom 7100 Motor Replacement
Qué necesitas
  1. Philips Norelco BG2040 BodyGroom 7100 Motor Replacement, LED Board: paso 1, imagen 1 de 2 Philips Norelco BG2040 BodyGroom 7100 Motor Replacement, LED Board: paso 1, imagen 2 de 2
    • Place thumb behind trimming blade and push up to open.
  2. Philips Norelco BG2040 BodyGroom 7100 Motor Replacement: paso 2, imagen 1 de 3 Philips Norelco BG2040 BodyGroom 7100 Motor Replacement: paso 2, imagen 2 de 3 Philips Norelco BG2040 BodyGroom 7100 Motor Replacement: paso 2, imagen 3 de 3
    • Remove two screws (M2 x 9.5) on metal plate with JIS 0 screwdriver bit.
    • Use spudger to pry off metal plate.
    • Slide up plastic housing to remove the trimmer.
  3. Philips Norelco BG2040 BodyGroom 7100 Motor Replacement: paso 3, imagen 1 de 3 Philips Norelco BG2040 BodyGroom 7100 Motor Replacement: paso 3, imagen 2 de 3 Philips Norelco BG2040 BodyGroom 7100 Motor Replacement: paso 3, imagen 3 de 3
    • Slide chrome outer plastic towards removed trimmer.
    • Flip to the other side and repeat, sliding the chrome plastic towards removed trimmer.
  4. Philips Norelco BG2040 BodyGroom 7100 Motor Replacement: paso 4, imagen 1 de 2 Philips Norelco BG2040 BodyGroom 7100 Motor Replacement: paso 4, imagen 2 de 2
    • Remove two top screws (M2 x 6.9) with the JIS 00 screwdriver bit.
    • Remove two bottom screws (M2 x 6.9) with the same bit.
  5. Philips Norelco BG2040 BodyGroom 7100 Motor Replacement: paso 5, imagen 1 de 3 Philips Norelco BG2040 BodyGroom 7100 Motor Replacement: paso 5, imagen 2 de 3 Philips Norelco BG2040 BodyGroom 7100 Motor Replacement: paso 5, imagen 3 de 3
    • Use spudger to pry off top of the battery cover. WARNING: fairly difficult, be aware significant amount of force required.
    • Use spudger to remove bottom of the battery cover, and remove it.
  6. Philips Norelco BG2040 BodyGroom 7100 Motor Replacement: paso 6, imagen 1 de 2 Philips Norelco BG2040 BodyGroom 7100 Motor Replacement: paso 6, imagen 2 de 2
    • Use a nylon spudger to pry out battery pack and the attached LED board.
  7. Philips Norelco BG2040 BodyGroom 7100 Motor Replacement: paso 7, imagen 1 de 3 Philips Norelco BG2040 BodyGroom 7100 Motor Replacement: paso 7, imagen 2 de 3 Philips Norelco BG2040 BodyGroom 7100 Motor Replacement: paso 7, imagen 3 de 3
    • Unwrap electrical tape around the battery pack and LED board.
    • Desolder the LED board from the battery pack.
    • Solder the new LED board back to the connection to battery pack.
  8. Philips Norelco BG2040 BodyGroom 7100 Motor Replacement, Motor: paso 8, imagen 1 de 3 Philips Norelco BG2040 BodyGroom 7100 Motor Replacement, Motor: paso 8, imagen 2 de 3 Philips Norelco BG2040 BodyGroom 7100 Motor Replacement, Motor: paso 8, imagen 3 de 3
    • *Please note that you do not need to remove the LED board from the battery pack for this guide. Begin the following steps after removal of the entire battery pack.*
    • Using the spudger, unclip the plastic housing around white casing.
    • Remove one half of the black housing first, and then proceed to the next half.
  9. Philips Norelco BG2040 BodyGroom 7100 Motor Replacement: paso 9, imagen 1 de 1
    • Once housing is removed, pull off shaver head. *Once black housing is removed this part may fall off*
  10. Philips Norelco BG2040 BodyGroom 7100 Motor Replacement: paso 10, imagen 1 de 3 Philips Norelco BG2040 BodyGroom 7100 Motor Replacement: paso 10, imagen 2 de 3 Philips Norelco BG2040 BodyGroom 7100 Motor Replacement: paso 10, imagen 3 de 3
    • Use spudger to pry motor out of the white housing.
    • Pull waterproofing case off of the motor.
Conclusión
2 personas más completaron esta guía.
August Post
Miembro Desde 11/07/17
415 Reputación
3 Guías creadas
Equipo
IUPUI, Team S2-G4, Harley Fall 2017 Miembro de IUPUI, Team S2-G4, Harley Fall 2017
IUPUI-HARLEY-F17S2G4
3 Miembros
4 Guías creadas
Un comentario
Great guide. Thanks
Steve Riggle - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 2
Ultimos 30 días: 18
Todo El Tiempo: 2,539
