Saltar al contenido principal
Philips Norelco 5801XL Battery Replacement
Qué necesitas
  1. Philips Norelco 5801XL Battery Replacement, Battery: paso 1, imagen 1 de 2 Philips Norelco 5801XL Battery Replacement, Battery: paso 1, imagen 2 de 2
    • Using a T8 torx screwdriver, remove both 2mm T8 screws.
  2. Philips Norelco 5801XL Battery Replacement: paso 2, imagen 1 de 2 Philips Norelco 5801XL Battery Replacement: paso 2, imagen 2 de 2
    • Using a plastic opening tool, separate the front housing from the back housing.
    • Carefully pull the housing apart.
  3. Philips Norelco 5801XL Battery Replacement: paso 3, imagen 1 de 3 Philips Norelco 5801XL Battery Replacement: paso 3, imagen 2 de 3 Philips Norelco 5801XL Battery Replacement: paso 3, imagen 3 de 3
    • Remove the plastic bracket using a plastic opening tool.
    • Pry from the inside of the bracket towards the outside of the housing to remove it.
  4. Philips Norelco 5801XL Battery Replacement: paso 4, imagen 1 de 1
    • Remove the two T8 2mm Philips screws holding onto the bracket over the charge port.
    • Remove the bracket. It will pull straight out.
  5. Philips Norelco 5801XL Battery Replacement: paso 5, imagen 1 de 1
    • Push in the charge port using the plastic opening tool.
  6. Philips Norelco 5801XL Battery Replacement: paso 6, imagen 1 de 1
    • Lift the circuit board upwards and fold it towards the head of the razor.
    • Do not break the contacts connecting the board to the motor.
  7. Philips Norelco 5801XL Battery Replacement: paso 7, imagen 1 de 3 Philips Norelco 5801XL Battery Replacement: paso 7, imagen 2 de 3 Philips Norelco 5801XL Battery Replacement: paso 7, imagen 3 de 3
    • Desolder the contacts where the battery connects to the circuit board.
    • Straighten the battery contacts and pull them through the opposite side of the circuit board.
Conclusión
3 personas más completaron esta guía.
Ben Gibbs
Miembro Desde 02/16/16
361 Reputación
3 Guías creadas
Equipo
IUPUI, Team 3-2, Harley Spring 2016 Miembro de IUPUI, Team 3-2, Harley Spring 2016
IUPUI-HARLEY-S16S3G2
4 Miembros
3 Guías creadas
2 comentarios
The replacement battery I bought had contact strips that were too long and too wide for the slots on the circuit board, so I had to trim off about half the length and 1.5 mm of the width on each strip, but after that alteration, it worked fine.
Tom Hess - Contestar
What size is the Rechargeable Battery in the Norelco 5801XL .
Dave - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 14
Ultimos 30 días: 55
Todo El Tiempo: 4,023
