Introducción
I found the instructions partly at this pages and decided to upload the completely new here:
http://www.brunwinkel.de/2011/09/wasserk... (german)
Qué necesitas
Remove top lid
Unscrew 5x Torx (T8)
Remove red cover
Remember position of metallic bracket
Unscrew 3 Torx T8 at the bottom of the kettle
take 3 big flat screwdriver to 3 of the 6 holes and gently apply pressure directed to the middle to unlock the bottom cover
in parallel: with a 3rd screwdriver lift the cover by help of the occuring slit at the side
bottom cover should be revomed with gently force
12 personas más completaron esta guía.
15 comentarios
Dear RG! You made me hero in the eyes of my wife and saved lots of money as I will never buy ordinary kettle without a temperature choice. THANKS FOR THE FANTASTIC GIUDE!
Two notes: (1) It should be mentioned that the MKP X2 0.47μF / 275V capacitor is usually the faulty one. The posts on the German site to which you linked reported that it looses capacity until the power is no longer enough to power the 80 degree LED when it comes on. In my case, similar to the reports from the German site, the remaining capacity had been lower than 0.14μF---clearly not enough. (2) One apparently does not have to use the 26.5 x 8.5 x 17 mm version that was part of the kettle initially, I had an old X2 capacitor from a broken power supply with the same parameters but with a size of 18 x 10 x 16 mm and that worked just fine after I had extended the short connecting wires.
