Introducción
We are going to teach you to replace the speaker, which involves soldering.
Qué necesitas
Turn the radio upside down.
On the places indicated by the red circles, 6 14.8mm Phillips #0 screws need to be removed using a Phillips 00 screwdriver.
Next the different screws indicated in the picture need to be removed.
The 5 9.5mm Phillips #0 screws indicated by the red circles need to be removed using a Phillips 00 screwdriver.
One 7.4mm Phillips #02 screw indicated by the blue circle needs to be removed using a Phillips 02 screwdriver
The last step is soldering the new speaker on. For this you need solder.
Melt the wires to the contacts of the new speaker, by melting some solder over the wired, touching the contact of the speaker.
Make sure to attach the black wire to the negative contact of the speaker (indicated on the speaker) and the white wire to the positive contact.
