Saltar al contenido principal
Introducción
In this guide, you will locate several screws that hold the top panel in place and remove them. They are all Phillips screws and are simple to remove.
Partes
No se especificaron partes.
  1. Remove four 7.5 mm Phillips screws on the both sides (2 on each side). Remove five 7.5 mm Phillips screws on the back of the player.
    • Remove four 7.5 mm Phillips screws on the both sides (2 on each side).
    • Remove five 7.5 mm Phillips screws on the back of the player.
  2. Lift the top panel from the back and remove.  It should come off without being forced.  There is a lip near the front so you many need to slide the top panel back slightly to remove it. Lift the top panel from the back and remove.  It should come off without being forced.  There is a lip near the front so you many need to slide the top panel back slightly to remove it.
    • Lift the top panel from the back and remove. It should come off without being forced. There is a lip near the front so you many need to slide the top panel back slightly to remove it.
Conclusión
3 personas más completaron esta guía.
Equipo
Cal Poly, Team 21-20, Maness Fall 2011 Miembro de Cal Poly, Team 21-20, Maness Fall 2011
CPSU-MANESS-F11S21G20
4 Miembros
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 889
