Saltar al contenido principal
Philips DVP642 Power Supply Replacement
Qué necesitas
  1. Philips DVP642 Power Supply Replacement, Top Panel: paso 1, imagen 1 de 2 Philips DVP642 Power Supply Replacement, Top Panel: paso 1, imagen 2 de 2
    • Remove four 7.5 mm Phillips screws on the both sides (2 on each side).
    • Remove five 7.5 mm Phillips screws on the back of the player.
  2. Philips DVP642 Power Supply Replacement: paso 2, imagen 1 de 2 Philips DVP642 Power Supply Replacement: paso 2, imagen 2 de 2
    • Lift the top panel from the back and remove. It should come off without being forced. There is a lip near the front so you many need to slide the top panel back slightly to remove it.
  3. Philips DVP642 Power Supply Replacement, Power Supply: paso 3, imagen 1 de 2 Philips DVP642 Power Supply Replacement, Power Supply: paso 3, imagen 2 de 2
    • Slide the power cord out from the case.
    • Be sure not to lose the rubber clip that is wrapped around the cord.
  4. Philips DVP642 Power Supply Replacement: paso 4, imagen 1 de 1
    • Remove the ribbon attached to the power supply by pushing the latch and gently pulling up.
  5. Philips DVP642 Power Supply Replacement: paso 5, imagen 1 de 2 Philips DVP642 Power Supply Replacement: paso 5, imagen 2 de 2
    • Now remove this ribbon wire by grasping the white head firmly and pulling up gently.
  6. Philips DVP642 Power Supply Replacement: paso 6, imagen 1 de 2 Philips DVP642 Power Supply Replacement: paso 6, imagen 2 de 2
    • Remove these two 7.5m Phillips screws and the matching set at the other end of the supply.
    • Now remove the ribbon that attaches the power supply to the motherboard by grasping the white head and gently pulling up.
  7. Philips DVP642 Power Supply Replacement: paso 7, imagen 1 de 3 Philips DVP642 Power Supply Replacement: paso 7, imagen 2 de 3 Philips DVP642 Power Supply Replacement: paso 7, imagen 3 de 3
    • Remove the last screw.
    • Pinch this plastic prong and slide the power supply up and over it. The power supply should lift free.
  8. Philips DVP642 Power Supply Replacement: paso 8, imagen 1 de 2 Philips DVP642 Power Supply Replacement: paso 8, imagen 2 de 2
    • Your power supply is now free!
    • If the fuse circled here is blown (the small wire in the glass tube is missing or broken), remove it by pinching it tightly and pulling it straight out.
    • You can find a new fuse here.
Conclusión
7 personas más completaron esta guía.
Equipo
Cal Poly, Team 21-20, Maness Fall 2011 Miembro de Cal Poly, Team 21-20, Maness Fall 2011
CPSU-MANESS-F11S21G20
4 Miembros
7 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 17
Ultimos 30 días: 56
Todo El Tiempo: 13,450
