Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Introducción
With constant use, the USB port can become broken or unresponsive. This guide will show you how to replace the USB port on your Philips DVP5992-F7.
Partes
No se especificaron partes.
  1. Remove the three 6.4 mm Phillips #1 screws on the back of the device with a Phillips head screwdriver. Remove the 6.4 mm Phillips #1 screws on each side of the device. Remove the 6.4 mm Phillips #1 screws on each side of the device.
    • Remove the three 6.4 mm Phillips #1 screws on the back of the device with a Phillips head screwdriver.
    • Remove the 6.4 mm Phillips #1 screws on each side of the device.
  2. Remove the top plate of the DVD by firmly grasping the player on both sides. Shift the top plate towards the backside of the player.
    • Remove the top plate of the DVD by firmly grasping the player on both sides.
    • Shift the top plate towards the backside of the player.
    • Lift the back half of the top plate up to remove it from the player.
  3. SALTEA LA ACTUALIZACIÓN
    Ahorra reparando con un kit todo en uno.
    Compra Kits de Reparación
  4. Locate the  bundled cable connectors that attaches the USB port to the motherboard. Firmly grasp the bundled cable connector and lift it from the motherboard. Firmly grasp the bundled cable connector and lift it from the motherboard.
    • Locate the bundled cable connectors that attaches the USB port to the motherboard.
    • Firmly grasp the bundled cable connector and lift it from the motherboard.
  5. Locate the area behind the USB port within the interior of the DVD Player. Unscrew the two 6.35 mm Phillips #1 screws located behind the USB port.
    • Locate the area behind the USB port within the interior of the DVD Player.
    • Unscrew the two 6.35 mm Phillips #1 screws located behind the USB port.
  6. Use the plastic opening tool to press down on the brass clip that holds the USB port in place. Pull back the USB Port to remove it from the DVD player.
    • Use the plastic opening tool to press down on the brass clip that holds the USB port in place.
    • Pull back the USB Port to remove it from the DVD player.
Conclusión
Nathan Sarti
Miembro Desde 31/08/18
253 Reputación
2 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 4
Todo El Tiempo: 177
