Saltar al contenido principal
Philips DVP5992-F7 Tray Replacement
Qué necesitas
  1. Philips DVP5992-F7 Tray Replacement, Tray: paso 1, imagen 1 de 3 Philips DVP5992-F7 Tray Replacement, Tray: paso 1, imagen 2 de 3 Philips DVP5992-F7 Tray Replacement, Tray: paso 1, imagen 3 de 3
    • Plug in the DVD player.
    • Press the eject button to open the tray.
    • Push up on the tray faceplate to remove it.
  2. Philips DVP5992-F7 Tray Replacement: paso 2, imagen 1 de 2 Philips DVP5992-F7 Tray Replacement: paso 2, imagen 2 de 2
    • Press the eject button to re-insert the tray.
    • Unplug the DVD player after the tray is closed.
  3. Philips DVP5992-F7 Tray Replacement: paso 3, imagen 1 de 3 Philips DVP5992-F7 Tray Replacement: paso 3, imagen 2 de 3 Philips DVP5992-F7 Tray Replacement: paso 3, imagen 3 de 3
    • Remove the three 6.4 mm Phillips #1 screws on the back of the device with a Phillips head screwdriver.
    • Remove the 6.4 mm Phillips #1 screws on each side of the device.
  4. Philips DVP5992-F7 Tray Replacement: paso 4, imagen 1 de 2 Philips DVP5992-F7 Tray Replacement: paso 4, imagen 2 de 2
    • Remove the top plate of the DVD by firmly grasping the player on both sides.
    • Shift the top plate towards the backside of the player.
    • Lift the back half of the top plate up to remove it from the player.
  5. Philips DVP5992-F7 Tray Replacement: paso 5, imagen 1 de 3 Philips DVP5992-F7 Tray Replacement: paso 5, imagen 2 de 3 Philips DVP5992-F7 Tray Replacement: paso 5, imagen 3 de 3
    • Locate the motherboard within the DVD player.
    • Firmly grasp the ribbon wire and unplug it from the motherboard.
  6. Philips DVP5992-F7 Tray Replacement: paso 6, imagen 1 de 2 Philips DVP5992-F7 Tray Replacement: paso 6, imagen 2 de 2
    • Firmly grasp the bundled cable connector that attaches the tray to the motherboard.
    • Gently pull upwards to remove the bundled cable connector from the motherboard.
  7. Philips DVP5992-F7 Tray Replacement: paso 7, imagen 1 de 2 Philips DVP5992-F7 Tray Replacement: paso 7, imagen 2 de 2
    • Firmly grasp the second bundled cable connector that attaches the tray to the motherboard.
    • Gently pull upwards to remove the second bundled cable connector from the motherboard.
  8. Philips DVP5992-F7 Tray Replacement: paso 8, imagen 1 de 2 Philips DVP5992-F7 Tray Replacement: paso 8, imagen 2 de 2
    • Remove the 9.0 mm #1 Phillips head screw that holds the tray to the DVD player.
  9. Philips DVP5992-F7 Tray Replacement: paso 9, imagen 1 de 2 Philips DVP5992-F7 Tray Replacement: paso 9, imagen 2 de 2
    • Lift the tray out of the DVD player from the back.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 19
Todo El Tiempo: 516
