Saltar al contenido principal
Philips DVP5992-F7 Screen Replacement
Qué necesitas
  1. Philips DVP5992-F7 Screen Replacement, Screen: paso 1, imagen 1 de 3 Philips DVP5992-F7 Screen Replacement, Screen: paso 1, imagen 2 de 3 Philips DVP5992-F7 Screen Replacement, Screen: paso 1, imagen 3 de 3
    • Remove the three 6.4 mm Phillips #1 screws on the back of the device with a Phillips head screwdriver.
    • Remove the 6.4 mm Phillips #1 screws on each side of the device.
  2. Philips DVP5992-F7 Screen Replacement: paso 2, imagen 1 de 2 Philips DVP5992-F7 Screen Replacement: paso 2, imagen 2 de 2
    • Remove the top plate of the DVD by firmly grasping the player on both sides.
    • Shift the top plate towards the backside of the player.
    • Lift the back half of the top plate up to remove it from the player.
  3. Philips DVP5992-F7 Screen Replacement: paso 3, imagen 1 de 3 Philips DVP5992-F7 Screen Replacement: paso 3, imagen 2 de 3 Philips DVP5992-F7 Screen Replacement: paso 3, imagen 3 de 3
    • Unplug the bundled cable connector that attaches the screen to the motherboard.
    • Remove the 3.175 mm Phillips #1 screw that connects the screen's ground wire to the shell of the DVD player.
    • Remove the three 6.35 mm Phillips #1 screws that attach the screen to the front cover of the DVD player.
  4. Philips DVP5992-F7 Screen Replacement: paso 4, imagen 1 de 2 Philips DVP5992-F7 Screen Replacement: paso 4, imagen 2 de 2
    • Slowly pull the screen backwards starting with the side farthest from the disc tray.
    • Unplug the bundled cable connector that is located close to the disc tray as you pull the screen out of the DVD player.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 16
Todo El Tiempo: 252
