Saltar al contenido principal
Philips DVP5992-F7 Power Cord Replacement
Qué necesitas
  1. Philips DVP5992-F7 Power Cord Replacement, Power Cord: paso 1, imagen 1 de 3 Philips DVP5992-F7 Power Cord Replacement, Power Cord: paso 1, imagen 2 de 3 Philips DVP5992-F7 Power Cord Replacement, Power Cord: paso 1, imagen 3 de 3
    • Remove the three 6.4 mm Phillips #1 screws on the back of the device with a Phillips head screwdriver.
    • Remove the 6.4 mm Phillips #1 screws on each side of the device.
  2. Philips DVP5992-F7 Power Cord Replacement: paso 2, imagen 1 de 2 Philips DVP5992-F7 Power Cord Replacement: paso 2, imagen 2 de 2
    • Remove the top plate of the DVD by firmly grasping the player on both sides.
    • Shift the top plate towards the backside of the player.
    • Lift the back half of the top plate up to remove it from the player.
  3. Philips DVP5992-F7 Power Cord Replacement: paso 3, imagen 1 de 3 Philips DVP5992-F7 Power Cord Replacement: paso 3, imagen 2 de 3 Philips DVP5992-F7 Power Cord Replacement: paso 3, imagen 3 de 3
    • Locate the power cable connector inside the DVD player.
    • Pinch down on both sides of the cable connector.
    • Gently pull upwards on the cable connector while wiggling it to remove it from the DVD player.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 3
Todo El Tiempo: 381
