Saltar al contenido principal
Philips DVP5992-F7 Audio Video Port Replacement
Qué necesitas
  1. Philips DVP5992-F7 Audio Video Port Replacement, Audio/Video Port: paso 1, imagen 1 de 3 Philips DVP5992-F7 Audio Video Port Replacement, Audio/Video Port: paso 1, imagen 2 de 3 Philips DVP5992-F7 Audio Video Port Replacement, Audio/Video Port: paso 1, imagen 3 de 3
    • Remove the three 6.4 mm Phillips #1 screws on the back of the device with a Phillips head screwdriver.
    • Remove the 6.4 mm Phillips #1 screws on each side of the device.
  2. Philips DVP5992-F7 Audio Video Port Replacement: paso 2, imagen 1 de 2 Philips DVP5992-F7 Audio Video Port Replacement: paso 2, imagen 2 de 2
    • Remove the top plate of the DVD by firmly grasping the player on both sides.
    • Shift the top plate towards the backside of the player.
    • Lift the back half of the top plate up to remove it from the player.
  3. Philips DVP5992-F7 Audio Video Port Replacement: paso 3, imagen 1 de 3 Philips DVP5992-F7 Audio Video Port Replacement: paso 3, imagen 2 de 3 Philips DVP5992-F7 Audio Video Port Replacement: paso 3, imagen 3 de 3
    • Unplug the one ribbon wire and the five bundled cable connectors that are plugged into the motherboard.
  4. Philips DVP5992-F7 Audio Video Port Replacement: paso 4, imagen 1 de 1
    • Remove the three 4.76 mm #1 Phillips head screws located on the back of the DVD player.
  5. Philips DVP5992-F7 Audio Video Port Replacement: paso 5, imagen 1 de 1
    • Remove the two 7.94 mm #1 Phillips head screws from the motherboard.
  6. Philips DVP5992-F7 Audio Video Port Replacement: paso 6, imagen 1 de 1
    • Remove the motherboard from the DVD player.
Conclusión
3 personas más completaron esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 14
Todo El Tiempo: 319
