Introducción
Ensure to have your replacement microphone lying next to you before you start disassembling your device.
You should also have a little bowl ready to set aside screws and other small parts.
Qué necesitas
Herramienta utilizada en este paso:Anti-Static Wrist Strap$7.95
Put on the Anti-Static Wrist Strap and clamp the end of the band to an unpainted spot of a radiator.
Unscrew the six Torx #4 (5,3 mm) screws from both sides of the device
Unscrew the eight Torx #4 (5,0 mm) screws from the motherboard.
These two screws connect the motherboard with the sliding cage. In this guide they are removed as well. Hence this is not compulsory you can decide for yourself whether you want to remove them now or later.
Preheat your soldering equipment.
Dissolve the soldering connection between motherboard and defective speaker.
To reassemble your device, follow these instructions in reverse order beginning with step 13.
