Saltar al contenido principal
Philips DC320 37 Headphone or Power Jack Replacement
Qué necesitas
  1. Philips DC320 37 Headphone or Power Jack Replacement, Docking entertainment system: paso 1, imagen 1 de 1
    • Pry off the four white feet with the pointed end of the spudger
  2. Philips DC320 37 Headphone or Power Jack Replacement: paso 2, imagen 1 de 1
    • Gently unscrew the four 15.5 mm Phillips #2 screws that hold the bottom panel to the dock.
  3. Philips DC320 37 Headphone or Power Jack Replacement: paso 3, imagen 1 de 1
    • Use the flat end of the spudger to pry the lid off from the two connectors holding it to the body of the dock.
    • The connectors on the panel are fragile and may break.
  4. Philips DC320 37 Headphone or Power Jack Replacement: paso 4, imagen 1 de 3 Philips DC320 37 Headphone or Power Jack Replacement: paso 4, imagen 2 de 3 Philips DC320 37 Headphone or Power Jack Replacement: paso 4, imagen 3 de 3
    • Carefully pull up and out the four electrical connectors and two ribbon connectors that connect the bottom panel to the dock.
    • Electrical Connectors
    • Ribbon Connectors
    • The cables do not have a lot of slack in them. Be careful not to break the connectors.
    • One wire is soldered onto the bottom panel. Be careful not to break this bond.
  5. Philips DC320 37 Headphone or Power Jack Replacement, Headphone or Power Jack: paso 5, imagen 1 de 1
    • Unscrew the two 5 mm Phillips #00 screws attaching white support bracket to the body of the device.
  6. Philips DC320 37 Headphone or Power Jack Replacement: paso 6, imagen 1 de 1
    • Unscrew the two 5 mm Phillips #00 screws from green Headphone/Power electronics board to detach from white support bracket.
  7. Philips DC320 37 Headphone or Power Jack Replacement: paso 7, imagen 1 de 1
    • Separate the white suport bracket from the headphone/power electronics board.
Conclusión
Graham Rolph
Miembro Desde 04/18/13
1 Reputación
2 Guías creadas
Equipo
Cal Poly, Team 3-48, Amido Spring 2013 Miembro de Cal Poly, Team 3-48, Amido Spring 2013
CPSU-AMIDO-S13S3G48
4 Miembros
6 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 1
Todo El Tiempo: 1,255
