Saltar al contenido principal
Philips DC320 37 Connector Replacement
Qué necesitas
  1. Philips DC320 37 Connector Replacement, Docking entertainment system: paso 1, imagen 1 de 1
    • Pry off the four white feet with the pointed end of the spudger
  2. Philips DC320 37 Connector Replacement: paso 2, imagen 1 de 1
    • Gently unscrew the four 15.5 mm Phillips #2 screws that hold the bottom panel to the dock.
  3. Philips DC320 37 Connector Replacement: paso 3, imagen 1 de 1
    • Use the flat end of the spudger to pry the lid off from the two connectors holding it to the body of the dock.
    • The connectors on the panel are fragile and may break.
  4. Philips DC320 37 Connector Replacement: paso 4, imagen 1 de 3 Philips DC320 37 Connector Replacement: paso 4, imagen 2 de 3 Philips DC320 37 Connector Replacement: paso 4, imagen 3 de 3
    • Carefully pull up and out the four electrical connectors and two ribbon connectors that connect the bottom panel to the dock.
    • Electrical Connectors
    • Ribbon Connectors
    • The cables do not have a lot of slack in them. Be careful not to break the connectors.
    • One wire is soldered onto the bottom panel. Be careful not to break this bond.
  5. Philips DC320 37 Connector Replacement, Connector: paso 5, imagen 1 de 1
    • Pull the copper plate out of the way of the two Phillips #00 screws in the middle of the connector.
  6. Philips DC320 37 Connector Replacement: paso 6, imagen 1 de 1
    • Unscrew the two 7 mm Phillips #00 screws holding the connector together.
    • Unscrew the four 5 mm Phillips #00 screws holding the connector to the dock
  7. Philips DC320 37 Connector Replacement: paso 7, imagen 1 de 3 Philips DC320 37 Connector Replacement: paso 7, imagen 2 de 3 Philips DC320 37 Connector Replacement: paso 7, imagen 3 de 3
    • Turn the dock so that you are looking at the front of the dock.
    • Pull out the black U-shaped piece.
    • Pull out the iPhone/iPod support cradle.
    • Pull out the two springs.
  8. Philips DC320 37 Connector Replacement: paso 8, imagen 1 de 1
    • Turn the dock so that you are looking at the bottom of the dock.
    • Pop out the black connector frame and attached circuit board from the body of the dock.
Conclusión
Greg Lane
Miembro Desde 04/16/13
39 Reputación
4 Guías creadas
Equipo
Cal Poly, Team 3-48, Amido Spring 2013 Miembro de Cal Poly, Team 3-48, Amido Spring 2013
CPSU-AMIDO-S13S3G48
4 Miembros
6 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 1
Todo El Tiempo: 1,227
