Saltar al contenido principal
Petzl E03 050 Headlamp Lens Piece Replacement
Qué necesitas
  1. Petzl E03 050 Headlamp Lens Piece Replacement, Extend the Damaged Lens Piece: paso 1, imagen 1 de 1
    • Remove the damaged lens piece by rotating the lens piece counterclockwise (left) until the lens piece is fully extended.
  2. Petzl E03 050 Headlamp Lens Piece Replacement, Remove the Lens Piece: paso 2, imagen 1 de 1
    • Remove the extended lens piece by firmly pulling the lens piece away from the battery housing. Take care to properly dispose of the damaged lens piece.
  3. Petzl E03 050 Headlamp Lens Piece Replacement, Attach the New Lens Piece: paso 3, imagen 1 de 1
    • Attach the new lens piece by firmly pressing the open end of the lens piece onto the battery housing.
  4. Petzl E03 050 Headlamp Lens Piece Replacement, Secure the New Lens Piece: paso 4, imagen 1 de 1
    • Secure the new lens piece onto the battery housing by turning the lens piece clockwise (right) until the headlamp turns on. You have just successfully replaced the lens piece.
Linea de Meta
Mike
Miembro Desde 10/23/14
331 Reputación
3 Guías creadas
Equipo
Baylor, Team 8-10, Williams Fall 2014 Miembro de Baylor, Team 8-10, Williams Fall 2014
BU-WILLIAMS-F14S8G10
3 Miembros
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 9
Ultimos 30 días: 14
Todo El Tiempo: 610
