Saltar al contenido principal
Petnet SmartFeeder SF10E Battery Replacement
Qué necesitas
  1. Petnet SmartFeeder SF10E Battery Replacement, Battery: paso 1, imagen 1 de 3 Petnet SmartFeeder SF10E Battery Replacement, Battery: paso 1, imagen 2 de 3 Petnet SmartFeeder SF10E Battery Replacement, Battery: paso 1, imagen 3 de 3
    • Eject the SmartBowl by pressing the button located at the front of the SmartFeeder base.
    • Remove the metal tray by using both hands and pulling out the bowl towards you.
  2. Petnet SmartFeeder SF10E Battery Replacement: paso 2, imagen 1 de 2 Petnet SmartFeeder SF10E Battery Replacement: paso 2, imagen 2 de 2
    • Turn the bowl tray side down by using both hands.
    • Remove seven 11 mm screws by using the Phillips #1 screwdriver.
  3. Petnet SmartFeeder SF10E Battery Replacement: paso 3, imagen 1 de 2 Petnet SmartFeeder SF10E Battery Replacement: paso 3, imagen 2 de 2
    Herramienta utilizada en este paso:
    Comprar
    • Take the battery out of the SmartBowl with tweezers, avoid pulling on any wires.
    • Hold the SmartBowl down using one hand while using the other hand to remove the battery.
  4. Petnet SmartFeeder SF10E Battery Replacement: paso 4, imagen 1 de 2 Petnet SmartFeeder SF10E Battery Replacement: paso 4, imagen 2 de 2
    • Remove the tape, closest to the four white connectors, with your hands.
    • Keep the wires attached to the tape for easy reassembly.
  5. Petnet SmartFeeder SF10E Battery Replacement: paso 5, imagen 1 de 2 Petnet SmartFeeder SF10E Battery Replacement: paso 5, imagen 2 de 2
    • Trace the wires with your hands from the battery to the motherboard.
    • Detach the three-prong connector between the battery and the motherboard by pulling the white connectors with your hands.
    • Hold on to the sockets on the motherboard or you could accidentally pull off the entire assembly.
Conclusión
Una persona más ha completado esta guía.
Equipo
Cal Poly, Team S13-G7, White Fall 2018 Miembro de Cal Poly, Team S13-G7, White Fall 2018
CPSU-WHITE-F18S13G7
4 Miembros
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 12
Todo El Tiempo: 550
