Saltar al contenido principal
Petnet SmartFeeder SF10E 12 Pin Connector Replacement
Qué necesitas
  1. Petnet SmartFeeder SF10E 12 Pin Connector Replacement, 12 Pin Connector: paso 1, imagen 1 de 3 Petnet SmartFeeder SF10E 12 Pin Connector Replacement, 12 Pin Connector: paso 1, imagen 2 de 3 Petnet SmartFeeder SF10E 12 Pin Connector Replacement, 12 Pin Connector: paso 1, imagen 3 de 3
    • Eject the SmartBowl by pressing the button located at the front of the SmartFeeder base.
  2. Petnet SmartFeeder SF10E 12 Pin Connector Replacement: paso 2, imagen 1 de 3 Petnet SmartFeeder SF10E 12 Pin Connector Replacement: paso 2, imagen 2 de 3 Petnet SmartFeeder SF10E 12 Pin Connector Replacement: paso 2, imagen 3 de 3
    • Remove the food tub by twisting it counter-clockwise with both hands and lifting it up.
  3. Petnet SmartFeeder SF10E 12 Pin Connector Replacement: paso 3, imagen 1 de 1
    • Remove the black plastic gasket from the top of the SmartFeeder by placing your fingers on the side of it and lifting up.
    • It should come off easily.
  4. Petnet SmartFeeder SF10E 12 Pin Connector Replacement: paso 4, imagen 1 de 1
    • Flip over the SmartFeeder by using both hands.
    • Partially open the outer case of the SmartFeeder by wedging an iFixit Opening Tool on each side.
  5. Petnet SmartFeeder SF10E 12 Pin Connector Replacement: paso 5, imagen 1 de 2 Petnet SmartFeeder SF10E 12 Pin Connector Replacement: paso 5, imagen 2 de 2
    • Turn the SmartFeeder on its side and with one hand on the base, carefully pull out the central section.
    • Place the bottom piece of the device right-side up.
  6. Petnet SmartFeeder SF10E 12 Pin Connector Replacement: paso 6, imagen 1 de 2 Petnet SmartFeeder SF10E 12 Pin Connector Replacement: paso 6, imagen 2 de 2
    • Remove one 10 mm screw by using the Phillips #1 screwdriver.
    • Remove the plastic retaining piece for the daughterboard by pulling it out with one hand.
  7. Petnet SmartFeeder SF10E 12 Pin Connector Replacement: paso 7, imagen 1 de 3 Petnet SmartFeeder SF10E 12 Pin Connector Replacement: paso 7, imagen 2 de 3 Petnet SmartFeeder SF10E 12 Pin Connector Replacement: paso 7, imagen 3 de 3
    • Pull the daughterboard out of the device and remove the three-prong connectors by using your hands.
    • Hold onto the sockets on the motherboard or you could accidentally pull off the entire assembly.
Conclusión
Ashley Kim
Miembro Desde 10/08/18
187 Reputación
1 Guía escrita
Equipo
Cal Poly, Team S13-G7, White Fall 2018 Miembro de Cal Poly, Team S13-G7, White Fall 2018
CPSU-WHITE-F18S13G7
4 Miembros
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 10
Todo El Tiempo: 297
