Saltar al contenido principal
Petmate 29027 Fountain Lid and Pump Replacement
Qué necesitas
  1. Petmate 29027 Fountain Lid and Pump Replacement, Fountain Lid and Pump: paso 1, imagen 1 de 3 Petmate 29027 Fountain Lid and Pump Replacement, Fountain Lid and Pump: paso 1, imagen 2 de 3 Petmate 29027 Fountain Lid and Pump Replacement, Fountain Lid and Pump: paso 1, imagen 3 de 3
    • Unplug the fountain from the electrical source and disconnect the inline plug.
    • Remove the lid.
    • Empty water from the fountain
    • Reach in the bowl and lift up the pump.
  2. Petmate 29027 Fountain Lid and Pump Replacement: paso 2, imagen 1 de 3 Petmate 29027 Fountain Lid and Pump Replacement: paso 2, imagen 2 de 3 Petmate 29027 Fountain Lid and Pump Replacement: paso 2, imagen 3 de 3
    • Unclip the lid and intake plate using a fingernail.
  3. Petmate 29027 Fountain Lid and Pump Replacement: paso 3, imagen 1 de 2 Petmate 29027 Fountain Lid and Pump Replacement: paso 3, imagen 2 de 2
    • Pry out the impeller (4 white bladed propellers) which is held in place magnetically.
    • You can use a fingernail or small needle nose pliers to get under the plastic blade and lift it out.
  4. Petmate 29027 Fountain Lid and Pump Replacement: paso 4, imagen 1 de 3 Petmate 29027 Fountain Lid and Pump Replacement: paso 4, imagen 2 de 3 Petmate 29027 Fountain Lid and Pump Replacement: paso 4, imagen 3 de 3
    • Clean the parts with warm soapy water and reassemble them.
    • Be sure to rinse thoroughly with fresh water.
    • Cleaning the motor with white vinegar (150ml) can increase disinfecting and hard water removal.
  5. Petmate 29027 Fountain Lid and Pump Replacement: paso 5, imagen 1 de 2 Petmate 29027 Fountain Lid and Pump Replacement: paso 5, imagen 2 de 2
    • Replace the pump into the original location.
    • Press down on the pump to engage the suction cups.
    • Place the fountain lid in the right place.
  6. Petmate 29027 Fountain Lid and Pump Replacement: paso 6, imagen 1 de 2 Petmate 29027 Fountain Lid and Pump Replacement: paso 6, imagen 2 de 2
    • Replug the fountain into electricity.
    • Add water as needed.
    • Never let the water level fall lower than the min fill line.
Linea de Meta
Shidie Ren
Miembro Desde 05/11/20
133 Reputación
1 Guía escrita
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 28
Todo El Tiempo: 507
