Saltar al contenido principal
Pentax ZX-5n Shutter Unit Replacement
Qué necesitas
  1. Pentax ZX-5n Shutter Unit Replacement, Remove back cover: paso 1, imagen 1 de 1
    • Push down on the screw to depress the spring loaded hinge and release the door.
  2. Pentax ZX-5n Shutter Unit Replacement, Remove bottom cover: paso 2, imagen 1 de 1
    • Remove six 5.3 mm #00 screws.
    • Remove one 3.4 mm #00 screw.
    • The short screw has a machine thread and screws into the plate underneath. The rest screw into the plastic body.
  3. Pentax ZX-5n Shutter Unit Replacement, Remove left front cover: paso 3, imagen 1 de 1
    • Remove three 5.3 mm #00 screws (the bottom-most screw is not always present).
    • Remove one 7.3 mm #00 screw.
    • Remove the remote trigger cover.
  4. Pentax ZX-5n Shutter Unit Replacement, Remove front cover: paso 4, imagen 1 de 2 Pentax ZX-5n Shutter Unit Replacement, Remove front cover: paso 4, imagen 2 de 2
    • Remove two 5.3 mm #00 screw.
    • Gently lift up on the flash housing to help remove the cover if necessary.
  5. Pentax ZX-5n Shutter Unit Replacement, Remove right front cover: paso 5, imagen 1 de 1
    • Remove two 3.9 mm #00 screws.
  6. Pentax ZX-5n Shutter Unit Replacement, Remove eye cup: paso 6, imagen 1 de 1
    • Slide the eye cup up and off to access the screws underneath.
  7. Pentax ZX-5n Shutter Unit Replacement, Unscrew top cover: paso 7, imagen 1 de 3 Pentax ZX-5n Shutter Unit Replacement, Unscrew top cover: paso 7, imagen 2 de 3 Pentax ZX-5n Shutter Unit Replacement, Unscrew top cover: paso 7, imagen 3 de 3
    • Remove two 5.3 mm #00 screws by the eyepiece.
    • Remove one 6.8 mm #00 screw in the battery compartment.
    • Remove one 7.0 mm #00 screw near the take up spool.
  8. Pentax ZX-5n Shutter Unit Replacement, Lift top cover: paso 8, imagen 1 de 1
    • Lift the cover so it is just free of the body. It is still attached by several wires.
  9. Pentax ZX-5n Shutter Unit Replacement, Discharge flash capacitors: paso 9, imagen 1 de 1
    • Use a 1kΩ-10kΩ resistor to discharge the capacitor. Place the resistor between the blue wire, exposed in the previous step, and ground.
    • The flash capacitors store energy at a very high voltage. Failing to discharge the capacitors properly could result in personal injury and/or damage to the camera.
  10. Pentax ZX-5n Shutter Unit Replacement, Unsolder flash connections: paso 10, imagen 1 de 1
    • Unsolder one green wire.
    • Unsolder one blue wire.
    • Unsolder one brown wire.
    • Unsolder one black wire.
  11. Pentax ZX-5n Shutter Unit Replacement, Unsolder remaining connections: paso 11, imagen 1 de 3 Pentax ZX-5n Shutter Unit Replacement, Unsolder remaining connections: paso 11, imagen 2 de 3 Pentax ZX-5n Shutter Unit Replacement, Unsolder remaining connections: paso 11, imagen 3 de 3
    • Pull black wire out from its routed location.
    • Unsolder flex connector
    • Be careful not to overheat the flex circuit. Work in short durations. Allow for cool downs in between if necessary.
    • Some repairs can be performed with the top cover still connected but the flex connection is fragile and easily damaged.
  12. Pentax ZX-5n Shutter Unit Replacement, De-solder battery connections: paso 12, imagen 1 de 1
    • De-solder the indicated joints. Use a solder sucker on the tabbed connections.
    • Pull the black wire from the battery flex to get more slack in the connection to the top cover.
  13. Pentax ZX-5n Shutter Unit Replacement, De-solder flex posts: paso 13, imagen 1 de 1
    • Use a solder sucker to de-solder the four posts from the flex circuit.
    • This is the most difficult part of the repair. Patience and persistence are required.
  14. Pentax ZX-5n Shutter Unit Replacement, De-solder flex connections: paso 14, imagen 1 de 1
    • Unsolder film advance motor connections.
    • Unsolder sprocket counter connections.
    • Unsolder power and ground connections.
    • Unsolder panorama switch connections.
  15. Pentax ZX-5n Shutter Unit Replacement, Unscrew flex circuit: paso 15, imagen 1 de 1
    • Remove one 4.3 mm #00 screw.
  16. Pentax ZX-5n Shutter Unit Replacement, Lift the flex circuit: paso 16, imagen 1 de 2 Pentax ZX-5n Shutter Unit Replacement, Lift the flex circuit: paso 16, imagen 2 de 2
    • Gently pry up the plastic carrier under the flex circuit. It may catch slightly on the battery contact tab.
    • Pay close attention to the connections around the four through-hole posts as you lift the flex. Make sure that no solder is left over and that it pulls away freely.
    • This metal tab is lightly held in place with lacquer and can easily come loose. Keep an eye on it.
  17. Pentax ZX-5n Shutter Unit Replacement, Unscrew flash PCB: paso 17, imagen 1 de 1
    • Remove one 3.3mm #00 screw.
    • Remove one 3.9 #00 screw.
    • De-solder the red wire.
    • Peel off the black tape. Leave it attached to the wires.
  18. Pentax ZX-5n Shutter Unit Replacement, Remove flash PCB and capacitors: paso 18, imagen 1 de 2 Pentax ZX-5n Shutter Unit Replacement, Remove flash PCB and capacitors: paso 18, imagen 2 de 2
    • Gently peel the flex circuit from the surface of the capacitor.
    • There may be additional adhesive underneath the larger capacitor.
    • Lift the two capacitors and the flash PCB out as a single unit.
    • The double sided tape used to secure the capacitors can be softened with isopropyl alcohol if necessary.
  19. Pentax ZX-5n Shutter Unit Replacement, Prepare bottom plate: paso 19, imagen 1 de 2 Pentax ZX-5n Shutter Unit Replacement, Prepare bottom plate: paso 19, imagen 2 de 2
    • Remove two 3.4 mm #00 screws. Remove the plate holding the contacts in place.
    • Peel tape from the plate. Leave the tape attached to the flex circuit.
    • Remove the flex circuits from their retaining studs.
  20. Pentax ZX-5n Shutter Unit Replacement, Remove bottom plate: paso 20, imagen 1 de 2 Pentax ZX-5n Shutter Unit Replacement, Remove bottom plate: paso 20, imagen 2 de 2
    • Remove one 3.3 mm #0 countersunk screw.
    • Remove one 3.9 mm #0 shoulder screw.
    • Remove four 3.3 mm #00 screws.
    • Pull a little slack through the housing on this flex cable.
    • Pop the plate off its posts, rotate slightly clockwise and pull gently through the loosened flex cable.
    • To the camera tech that left me a happy little note...I see you.
  21. Pentax ZX-5n Shutter Unit Replacement, Remove transport gears: paso 21, imagen 1 de 2 Pentax ZX-5n Shutter Unit Replacement, Remove transport gears: paso 21, imagen 2 de 2
    • It's best to remove these parts now so they don't fall out later on in the repair.
  22. Pentax ZX-5n Shutter Unit Replacement, Detach DOF preview switch: paso 22, imagen 1 de 1
    • Remove one 3.8 mm #00 screw.
  23. Pentax ZX-5n Shutter Unit Replacement, De-solder shutter control flex: paso 23, imagen 1 de 2 Pentax ZX-5n Shutter Unit Replacement, De-solder shutter control flex: paso 23, imagen 2 de 2
    • De-solder the connections.
    • Lift the flex off the retaining studs.
  24. Pentax ZX-5n Shutter Unit Replacement, Remove eye piece assembly: paso 24, imagen 1 de 1
    • Remove two 5.3 mm #0 screws.
  25. Pentax ZX-5n Shutter Unit Replacement, Unscrew front housing block: paso 25, imagen 1 de 2 Pentax ZX-5n Shutter Unit Replacement, Unscrew front housing block: paso 25, imagen 2 de 2
    • Remove two 7.4 mm #0 screws.
    • Remove one 8.3 mm #0 screw.
    • Remove one 3.3 mm #00 screw. The metal bracket will be loose and should be removed as well.
  26. Pentax ZX-5n Shutter Unit Replacement, Lift front housing block: paso 26, imagen 1 de 1
    • Push the front housing block slightly up then lift the left side up and away from the housing.
    • Proceed slowly and watch for any components that are catching. The right side is still attached by a large flex cable.
  27. Pentax ZX-5n Shutter Unit Replacement, Check for shims: paso 27, imagen 1 de 1
    • There may be shims at the mounting points of the front housing block.
    • Note the positions and remove if loose.
  28. Pentax ZX-5n Shutter Unit Replacement, Remove panorama switch: paso 28, imagen 1 de 3 Pentax ZX-5n Shutter Unit Replacement, Remove panorama switch: paso 28, imagen 2 de 3 Pentax ZX-5n Shutter Unit Replacement, Remove panorama switch: paso 28, imagen 3 de 3
    • Remove one X mm #00 screw.
    • Remove panorama switch contact.
    • Pull panorama switch apart and remove both pieces.
  29. Pentax ZX-5n Shutter Unit Replacement, Remove shutter unit: paso 29, imagen 1 de 2 Pentax ZX-5n Shutter Unit Replacement, Remove shutter unit: paso 29, imagen 2 de 2
    • Remove two X mm #00 screw.
    • Remove shutter unit.
Conclusión
Sam Gustafson
Miembro Desde 09/01/22
7,682 Reputación
42 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 5
Ultimos 30 días: 16
Todo El Tiempo: 29
