Saltar al contenido principal
Pentax ZX-5n Exposure Compensation Dial Replacement
Qué necesitas
  1. Pentax ZX-5n Exposure Compensation Dial Replacement, Remove back cover: paso 1, imagen 1 de 1
    • Push down on the screw to depress the spring loaded hinge and release the door.
  2. Pentax ZX-5n Exposure Compensation Dial Replacement, Remove bottom cover: paso 2, imagen 1 de 1
    • Remove six 5.3 mm #00 screws.
    • Remove one 3.4 mm #00 screw.
    • The short screw has a machine thread and screws into the plate underneath. The rest screw into the plastic body.
  3. Pentax ZX-5n Exposure Compensation Dial Replacement, Remove left front cover: paso 3, imagen 1 de 1
    • Remove three 5.3 mm #00 screws (the bottom-most screw is not always present).
    • Remove one 7.3 mm #00 screw.
    • Remove the remote trigger cover.
  4. Pentax ZX-5n Exposure Compensation Dial Replacement, Remove front cover: paso 4, imagen 1 de 2 Pentax ZX-5n Exposure Compensation Dial Replacement, Remove front cover: paso 4, imagen 2 de 2
    • Remove two 5.3 mm #00 screw.
    • Gently lift up on the flash housing to help remove the cover if necessary.
  5. Pentax ZX-5n Exposure Compensation Dial Replacement, Remove right front cover: paso 5, imagen 1 de 1
    • Remove two 3.9 mm #00 screws.
  6. Pentax ZX-5n Exposure Compensation Dial Replacement, Remove eye cup: paso 6, imagen 1 de 1
    • Slide the eye cup up and off to access the screws underneath.
  7. Pentax ZX-5n Exposure Compensation Dial Replacement, Unscrew top cover: paso 7, imagen 1 de 3 Pentax ZX-5n Exposure Compensation Dial Replacement, Unscrew top cover: paso 7, imagen 2 de 3 Pentax ZX-5n Exposure Compensation Dial Replacement, Unscrew top cover: paso 7, imagen 3 de 3
    • Remove two 5.3 mm #00 screws by the eyepiece.
    • Remove one 6.8 mm #00 screw in the battery compartment.
    • Remove one 7.0 mm #00 screw near the take up spool.
  8. Pentax ZX-5n Exposure Compensation Dial Replacement, Lift top cover: paso 8, imagen 1 de 1
    • Lift the cover so it is just free of the body. It is still attached by several wires.
  9. Pentax ZX-5n Exposure Compensation Dial Replacement, Discharge flash capacitors: paso 9, imagen 1 de 1
    • Use a 1kΩ-10kΩ resistor to discharge the capacitor. Place the resistor between the blue wire, exposed in the previous step, and ground.
    • The flash capacitors store energy at a very high voltage. Failing to discharge the capacitors properly could result in personal injury and/or damage to the camera.
  10. Pentax ZX-5n Exposure Compensation Dial Replacement, Unsolder flash connections: paso 10, imagen 1 de 1
    • Unsolder one green wire.
    • Unsolder one blue wire.
    • Unsolder one brown wire.
    • Unsolder one black wire.
  11. Pentax ZX-5n Exposure Compensation Dial Replacement, Unsolder remaining connections: paso 11, imagen 1 de 3 Pentax ZX-5n Exposure Compensation Dial Replacement, Unsolder remaining connections: paso 11, imagen 2 de 3 Pentax ZX-5n Exposure Compensation Dial Replacement, Unsolder remaining connections: paso 11, imagen 3 de 3
    • Pull black wire out from its routed location.
    • Unsolder flex connector
    • Be careful not to overheat the flex circuit. Work in short durations. Allow for cool downs in between if necessary.
    • Some repairs can be performed with the top cover still connected but the flex connection is fragile and easily damaged.
  12. Pentax ZX-5n Exposure Compensation Dial Replacement, Set exposure compensation: paso 12, imagen 1 de 1
    • Set the exposure compensation dial to '0'.
  13. Pentax ZX-5n Exposure Compensation Dial Replacement, Remove screws: paso 13, imagen 1 de 1
    • Remove two #00 screws
    • Be careful not to damage the feeler contacts from the drive mode switch throughout the repair. There are delicate and easily bent.
  14. Pentax ZX-5n Exposure Compensation Dial Replacement, Remove contact PCB: paso 14, imagen 1 de 2 Pentax ZX-5n Exposure Compensation Dial Replacement, Remove contact PCB: paso 14, imagen 2 de 2
    • Remove the contact PCB.
    • There is a metal plate underneath that may stick to the PCB.
  15. Pentax ZX-5n Exposure Compensation Dial Replacement, Remove dial: paso 15, imagen 1 de 1
    • Slide the exposure compensation dial out of the top cover.
    • If the dial was not set to '0' in Step 10, the knob will not slide out. Turning the knob at this stage could damage the detent spring.
  16. Pentax ZX-5n Exposure Compensation Dial Replacement, Remove detent components: paso 16, imagen 1 de 2 Pentax ZX-5n Exposure Compensation Dial Replacement, Remove detent components: paso 16, imagen 2 de 2
    • Remove the ball bearing from the inside of the dial.
    • Remove the detent spring from the top cover.
  17. Pentax ZX-5n Exposure Compensation Dial Replacement, Remove c-clip: paso 17, imagen 1 de 1
    • Remove the small plastic c-clip on the end of the shaft.
    • Place your finger over the c-clip whenever you are working with it to prevent it from unexpectedly flying away.
  18. Pentax ZX-5n Exposure Compensation Dial Replacement, Remove inner components: paso 18, imagen 1 de 3 Pentax ZX-5n Exposure Compensation Dial Replacement, Remove inner components: paso 18, imagen 2 de 3 Pentax ZX-5n Exposure Compensation Dial Replacement, Remove inner components: paso 18, imagen 3 de 3
    • Remove the lock button.
    • Remove the lock actuator.
    • Remove the lock spring.
  19. Pentax ZX-5n Exposure Compensation Dial Replacement, Reassembly notes: paso 19, imagen 1 de 2 Pentax ZX-5n Exposure Compensation Dial Replacement, Reassembly notes: paso 19, imagen 2 de 2
    • Use tape to hold components in place when reassembling the lock button and installing the dial.
Conclusión
Una persona más ha completado esta guía.
Sam Gustafson
Miembro Desde 09/01/22
7,682 Reputación
42 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 6
Todo El Tiempo: 249
