Saltar al contenido principal
Pentax Optio WG-3 GPS Shutter and Power Button Replacement
Qué necesitas
  1. Pentax Optio WG-3 GPS Shutter and Power Button Replacement, Shutter and Power Button: paso 1, imagen 1 de 1
    • Peel the lining back on the top of the camera.
    • The lining is glued down to the device, you will have to peel the lining back using tweezers. After you are finished with your work you will have to use glue or adhesive to re-stick the lining back to the device.
  2. Pentax Optio WG-3 GPS Shutter and Power Button Replacement: paso 2, imagen 1 de 1
    • Using tweezers pull straight up to remove the 2 rubber button toppers
  3. Pentax Optio WG-3 GPS Shutter and Power Button Replacement: paso 3, imagen 1 de 1
    • Remove the 3, 2 mm screws under the rubber buttons.
  4. Pentax Optio WG-3 GPS Shutter and Power Button Replacement: paso 4, imagen 1 de 1
    • Replace the shutter/power button or button component.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 2
Todo El Tiempo: 644
