Saltar al contenido principal
Pentax Optio WG-3 GPS Motherboard Replacement
Qué necesitas
  1. Pentax Optio WG-3 GPS Motherboard Replacement, Motherboard: paso 1, imagen 1 de 1
    • Turn over the camera so the screen is facing up.
    • Remove the four 5 mm Phillips #000 screws that secure the outer cover.
  2. Pentax Optio WG-3 GPS Motherboard Replacement: paso 2, imagen 1 de 1
    • Flip over the camera so the bottom is facing up.
    • Use the Phillips PH0005 again to remove one more 5mm screw.
    • Remove the cover.
  3. Pentax Optio WG-3 GPS Motherboard Replacement: paso 3, imagen 1 de 1
    • Remove the eight 5 mm Phillips #000 screws holding the circuitry together.
  4. Pentax Optio WG-3 GPS Motherboard Replacement: paso 4, imagen 1 de 1
    • Carefully remove the circuitry.
  5. Pentax Optio WG-3 GPS Motherboard Replacement: paso 5, imagen 1 de 1
    • There is a large silver sticker on top of the motherboard, gently remove it off of the motherboard.
  6. Pentax Optio WG-3 GPS Motherboard Replacement: paso 6, imagen 1 de 1
    • Gently use the spudger set to lift open the clamps that are holding the orange ribbons down.
    • Pull out the ribbons and remove the motherboard from the body of the camera.
  7. Pentax Optio WG-3 GPS Motherboard Replacement: paso 7, imagen 1 de 1
    • Remove the battery on the back of the motherboard.
  8. Pentax Optio WG-3 GPS Motherboard Replacement: paso 8, imagen 1 de 1
    • Unscrew and remove one 2 mm Phillips #00 screw to remove the flash component on the top of the circuitry.
  9. Pentax Optio WG-3 GPS Motherboard Replacement: paso 9, imagen 1 de 1
    • Remove three 5 mm Phillips #000 screws from the left side of the motherboard.
  10. Pentax Optio WG-3 GPS Motherboard Replacement: paso 10, imagen 1 de 1
    • Remove two ribbon cables from the small circuit.
    • Remove the ribbon cable that holds the sensor to the motherboard.
  11. Pentax Optio WG-3 GPS Motherboard Replacement: paso 11, imagen 1 de 1
    • The sensor is ready to be pulled out, carefully remove the sensor.
  12. Pentax Optio WG-3 GPS Motherboard Replacement: paso 12, imagen 1 de 1
    • Unscrew and remove three 5 mm screws from the front panel of the battery compartment.
  13. Pentax Optio WG-3 GPS Motherboard Replacement: paso 13, imagen 1 de 1
    • Pull the black panel away from the front panel.
  14. Pentax Optio WG-3 GPS Motherboard Replacement: paso 14, imagen 1 de 1
    • At the top of the circuit board there are three soldered dots that need to be unsoldered to remove the back of the battery component from the motherboard.
    • The motherboard can now be pulled and replaced.
Conclusión
Garrett Rose
Miembro Desde 03/31/22
373 Reputación
2 Guías creadas
Equipo
IUPUI, Team 3-1, Harley Spring 2022 Miembro de IUPUI, Team 3-1, Harley Spring 2022
IUPUI-HARLEY-S22S3G1
3 Miembros
3 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 18
Todo El Tiempo: 237
