Saltar al contenido principal
Pentax Optio WG-3 GPS Lens Assembly Replacement
Qué necesitas
  1. Pentax Optio WG-3 GPS Lens Assembly  Replacement, Lens Assembly: paso 1, imagen 1 de 1
    • Turn over the camera so the screen is facing up.
    • Remove the four 5 mm Phillips #000 screws that secure the outer cover.
  2. Pentax Optio WG-3 GPS Lens Assembly  Replacement: paso 2, imagen 1 de 1
    • Flip over the camera so the bottom is facing up.
    • Remove the single Phillips #000 screw.
    • Remove the cover.
  3. Pentax Optio WG-3 GPS Lens Assembly  Replacement: paso 3, imagen 1 de 1
    • Remove the eight 5 mm Phillips #000 screws holding the circuitry together.
  4. Pentax Optio WG-3 GPS Lens Assembly  Replacement: paso 4, imagen 1 de 1
    • Carefully remove the circuitry.
  5. Pentax Optio WG-3 GPS Lens Assembly  Replacement: paso 5, imagen 1 de 1
    • Flip the circuitry so that the lens is facing up and the flash component is on your right.
    • Identify the orange ribbon tape surrounding the lens.
  6. Pentax Optio WG-3 GPS Lens Assembly  Replacement: paso 6, imagen 1 de 1
    • There are three 5 mm Phillips #000 screws to be removed on the right side of the lens.
  7. Pentax Optio WG-3 GPS Lens Assembly  Replacement: paso 7, imagen 1 de 1
    • Gently slide the lens piece to the right, remove the tape and take it out.
Conclusión
Garrett Rose
Miembro Desde 03/31/22
373 Reputación
2 Guías creadas
Equipo
IUPUI, Team 3-1, Harley Spring 2022 Miembro de IUPUI, Team 3-1, Harley Spring 2022
IUPUI-HARLEY-S22S3G1
3 Miembros
3 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 16
Todo El Tiempo: 194
