Saltar al contenido principal
Pentax Optio WG-3 GPS Flash Replacement
Qué necesitas
  1. Pentax Optio WG-3 GPS Flash Replacement, Flash: paso 1, imagen 1 de 1
    • Turn over the camera so the screen is facing up.
    • Remove the four 5 mm Phillips #000 screws that secure the outer cover.
  2. Pentax Optio WG-3 GPS Flash Replacement: paso 2, imagen 1 de 1
    • Flip over the camera so the bottom is facing up.
    • Remove the single Phillips #000 screw.
    • Remove the cover.
  3. Pentax Optio WG-3 GPS Flash Replacement: paso 3, imagen 1 de 1
    • Remove the eight 5 mm Phillips #000 screws holding the circuitry together.
  4. Pentax Optio WG-3 GPS Flash Replacement: paso 4, imagen 1 de 1
    • Carefully remove the circuitry.
  5. Pentax Optio WG-3 GPS Flash Replacement: paso 5, imagen 1 de 1
    • Upon removing the flash, there is a 2 mm screw that needs to be removed.
  6. Pentax Optio WG-3 GPS Flash Replacement: paso 6, imagen 1 de 1
    • Remove the ribbon cable that attaches the flash from the circuitry.
  7. Pentax Optio WG-3 GPS Flash Replacement: paso 7, imagen 1 de 1
    • Remove the three 2 mm Phillips #000 screws from the left side of the circuitry.
    • These screws attach the circuit board to the shell of the camera.
    • Remove the circuitry from the front side of the camera
  8. Pentax Optio WG-3 GPS Flash Replacement: paso 8, imagen 1 de 1
    • Find and remove the camera battery.
  9. Pentax Optio WG-3 GPS Flash Replacement: paso 9, imagen 1 de 1
    • Remove the final two 2 mm Phillips #000 screws from the front side of the circuitry.
  10. Pentax Optio WG-3 GPS Flash Replacement: paso 10, imagen 1 de 1
    • Pull the black front panel away from the circuitry.
    • The black panel is attached to the flash and is now ready to be removed and replaced.
    • The sensor is enclosed in the white case.
Conclusión
Cassandra Stec
Miembro Desde 03/14/22
181 Reputación
1 Guía escrita
Equipo
IUPUI, Team 3-1, Harley Spring 2022 Miembro de IUPUI, Team 3-1, Harley Spring 2022
IUPUI-HARLEY-S22S3G1
3 Miembros
3 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 15
Todo El Tiempo: 199
