Saltar al contenido principal
Pentax Optio S4i Front and Back Cover Replacement
Qué necesitas
  1. Pentax Optio S4i Front and Back Cover Replacement, Front and Back Cover: paso 1, imagen 1 de 2 Pentax Optio S4i Front and Back Cover Replacement, Front and Back Cover: paso 1, imagen 2 de 2
    • Remove the following screws:
    • Two silver 3.15mm Phillips #00 screws on the right side of the camera
    • Two silver 2.08mm Phillips #00 screws on the left side of the camera
  2. Pentax Optio S4i Front and Back Cover Replacement: paso 2, imagen 1 de 1
    • Remove the two indicated screws on the bottom of the camera:
    • The screw circled in red is a longer silver 3.15mm Phillips #00 screw
    • The screw circled in blue is a shorter silver 2.25mm Phillips #00 screw
  3. Pentax Optio S4i Front and Back Cover Replacement: paso 3, imagen 1 de 2 Pentax Optio S4i Front and Back Cover Replacement: paso 3, imagen 2 de 2
    • Carefully pull the back of casing away from the front.
  4. Pentax Optio S4i Front and Back Cover Replacement: paso 4, imagen 1 de 3 Pentax Optio S4i Front and Back Cover Replacement: paso 4, imagen 2 de 3 Pentax Optio S4i Front and Back Cover Replacement: paso 4, imagen 3 de 3
    • After removing the back cover, several things must be removed.
    • Silver donut-shaped button will fall off. Place separately. Remove the plug covers on the right side of camera, labeled “PC/AV” and “DC IN 4.5V”.
  5. Pentax Optio S4i Front and Back Cover Replacement: paso 5, imagen 1 de 2 Pentax Optio S4i Front and Back Cover Replacement: paso 5, imagen 2 de 2
    • To remove the front cover, gently hold the inside structure of the camera and slowly pull the front cover off.
Conclusión
Una persona más ha completado esta guía.
Nicole Wong
Miembro Desde 01/30/11
329 Reputación
3 Guías creadas
Equipo
Cal Poly, Team 4-29, Regan Winter 2011 Miembro de Cal Poly, Team 4-29, Regan Winter 2011
CPSU-REGAN-W11S4G29
3 Miembros
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 2
Ultimos 30 días: 12
Todo El Tiempo: 3,225
