Saltar al contenido principal
Penny Board Trucks Replacement
Qué necesitas
  1. Penny Board Trucks Replacement, Trucks: paso 1, imagen 1 de 2 Penny Board Trucks Replacement, Trucks: paso 1, imagen 2 de 2
    • Use a skate tool to loosen the bolt in the wheel with an appropriately sized socket.
    • A skate tool will come with all the tools necessary to do this replacement from start to finish.
  2. Penny Board Trucks Replacement: paso 2, imagen 1 de 2 Penny Board Trucks Replacement: paso 2, imagen 2 de 2
    • Remove the wheel by lifting it from the truck.
    • Repeat this step for the other wheel.
  3. Penny Board Trucks Replacement: paso 3, imagen 1 de 2 Penny Board Trucks Replacement: paso 3, imagen 2 de 2
    • After completing the removal of both wheels, your board will look like this.
    • Place the skate tool over the bolt on the truck.
    • Maintain a good grip on the tool and use the Phillips screwdriver to loosen the nuts.
    • Repeat this step for all four screws.
  4. Penny Board Trucks Replacement: paso 4, imagen 1 de 2 Penny Board Trucks Replacement: paso 4, imagen 2 de 2
    • Lift the truck to remove it.
  5. Penny Board Trucks Replacement: paso 5, imagen 1 de 2 Penny Board Trucks Replacement: paso 5, imagen 2 de 2
    • Remove the screws from the board by pulling them out with your hands.
    • Use the Phillips screwdriver to loosen them more, if necessary.
Conclusión
Eduardo Ron
Miembro Desde 02/17/21
171 Reputación
1 Guía escrita
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 17
Todo El Tiempo: 542
