Saltar al contenido principal
Penguin FZ-8 28” Tower Fan Blade Replacement
Qué necesitas
  1. Penguin FZ-8 28” Tower Fan Blade Replacement, Fan Blade: paso 1, imagen 1 de 1
    • Flip the fan onto its side so that you can access the base of the fan.
    • Remove the single 11 mm screw using a Phillips #1 screwdriver.
  2. Penguin FZ-8 28” Tower Fan Blade Replacement: paso 2, imagen 1 de 3 Penguin FZ-8 28” Tower Fan Blade Replacement: paso 2, imagen 2 de 3 Penguin FZ-8 28” Tower Fan Blade Replacement: paso 2, imagen 3 de 3
    • Rotate the base of the fan counter-clockwise to detach it from the rest of the fan. The base can be separated into two parts.
  3. Penguin FZ-8 28” Tower Fan Blade Replacement: paso 3, imagen 1 de 2 Penguin FZ-8 28” Tower Fan Blade Replacement: paso 3, imagen 2 de 2
    • Remove four 5 mm screws from the sides of the base of the fan using the Phillips #1 screwdriver.
  4. Penguin FZ-8 28” Tower Fan Blade Replacement: paso 4, imagen 1 de 2 Penguin FZ-8 28” Tower Fan Blade Replacement: paso 4, imagen 2 de 2
    • Remove the two 5 mm screws located on the outside of the case inside the holes using the Phillips #1 screwdriver.
  5. Penguin FZ-8 28” Tower Fan Blade Replacement: paso 5, imagen 1 de 2 Penguin FZ-8 28” Tower Fan Blade Replacement: paso 5, imagen 2 de 2
    • Remove a single 5 mm screw on the outside cover of the fan using the Phillips #1 screwdriver.
    • Gently lift the top cover of the fan halfway to expose the single 5 mm screw. Remove this screw using the same Phillips #1 screwdriver.
  6. Penguin FZ-8 28” Tower Fan Blade Replacement: paso 6, imagen 1 de 2 Penguin FZ-8 28” Tower Fan Blade Replacement: paso 6, imagen 2 de 2
    • Pinch the sides of the case to remove the case from the rest of the fan.
  7. Penguin FZ-8 28” Tower Fan Blade Replacement: paso 7, imagen 1 de 1
    • Remove the single 5 mm screw between the fan blade and the motor using the Phillips #1 screwdriver.
  8. Penguin FZ-8 28” Tower Fan Blade Replacement: paso 8, imagen 1 de 2 Penguin FZ-8 28” Tower Fan Blade Replacement: paso 8, imagen 2 de 2
    • Remove the two 5 mm screws holding the fan blade in place using the Phillips #1 screwdriver.
  9. Penguin FZ-8 28” Tower Fan Blade Replacement: paso 9, imagen 1 de 1
    • Remove the fan blade from the device and clean it off before reassembling your device.
Conclusión
Ethan
Miembro Desde 03/22/21
169 Reputación
1 Guía escrita
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 13
Ultimos 30 días: 39
Todo El Tiempo: 925
