Introducción
This guide is explaining how to properly fix a Penguin 28” Tower Fan. Before starting to disassemble the fan make sure the fan is unplugged. This repair is helpful if you are trying to remove any plastic parts in front of the fan blade or if the blade needs to be cleaned. All of the screws are the same size, 5mm Philips head, excluding the one on the base of the fan.
Qué necesitas
Flip the fan onto its side so that you can access the base of the fan.
Remove the single 11 mm screw using a Phillips #1 screwdriver.
