Saltar al contenido principal
Pebble Time Round Glass Screen Protector Replacement
Qué necesitas
  1. Pebble Time Round Glass Screen Protector Replacement, Glass Screen Protector: paso 1, imagen 1 de 1
    • Wedge an opening tool between the case of the watch, and the glass screen bezel.
    • Pry the screen bezel away from the device.
    • If you have a difficult time getting the front bezel to separate from the case, try warming the watch up with a hair dryer.
    • There are three very tiny springs that are compressed between holes in the case and the front bezel. They can pop out once the bezel is removed, so don't lose them! Remove them and put them somewhere safe once the bezel is removed.
  2. Pebble Time Round Glass Screen Protector Replacement: paso 2, imagen 1 de 1
    • Pull the screen protector away from the device, breaking glue sealant.
    • Separate the screen protector from the screen.
    • To re-seal the glass protector's glue, simply heat the glue.
Conclusión
Kyle
Miembro Desde 11/01/21
85 Reputación
1 Guía escrita
Equipo
UMass Dartmouth, Team 4-5, Gulbrandsen Fall 2021 Miembro de UMass Dartmouth, Team 4-5, Gulbrandsen Fall 2021
UMASSD-GULBRANDSEN-F21S4G5
Miembros de 4
5 Guías creadas
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 3
Ultimos 30 días: 21
Todo El Tiempo: 533
