Saltar al contenido principal
Pebble Time Circuit Board Replacement
Qué necesitas
  1. Pebble Time Circuit Board Replacement, Screen Cover: paso 1, imagen 1 de 1
    • Lay the watch flat on your workstation.
  2. Pebble Time Circuit Board Replacement: paso 2, imagen 1 de 2 Pebble Time Circuit Board Replacement: paso 2, imagen 2 de 2
    • Use the metal spudger to carefully pull apart the screen cover from the case.
    • Replace the metal spudger with a plastic opening tool to hold the cover open.
  3. Pebble Time Circuit Board Replacement: paso 3, imagen 1 de 1
    • Use the metal spudger tool to carefully loosen the rest of the cover.
  4. Pebble Time Circuit Board Replacement: paso 4, imagen 1 de 1
    • Carefully, pull apart the cover with the plastic opening tool.
  5. Pebble Time Circuit Board Replacement, Screen: paso 5, imagen 1 de 1
    • Insert metal spudger into the side of the screen shown in the picture.
  6. Pebble Time Circuit Board Replacement: paso 6, imagen 1 de 1
    • Use the metal spudger to pry the screen up.
  7. Pebble Time Circuit Board Replacement: paso 7, imagen 1 de 3 Pebble Time Circuit Board Replacement: paso 7, imagen 2 de 3 Pebble Time Circuit Board Replacement: paso 7, imagen 3 de 3
    • Once screen is lifted, insert plastic opening tool between the screen connector and circuit board.
    • Disconnect the screen from the circuit board.
  8. Pebble Time Circuit Board Replacement, Circuit Board: paso 8, imagen 1 de 1
    • Keep the watch flat on your workstation.
  9. Pebble Time Circuit Board Replacement: paso 9, imagen 1 de 1
    • Locate the three screws on the circuit board.
    • Remove using the J000 Philips head screwdriver.
  10. Pebble Time Circuit Board Replacement: paso 10, imagen 1 de 3 Pebble Time Circuit Board Replacement: paso 10, imagen 2 de 3 Pebble Time Circuit Board Replacement: paso 10, imagen 3 de 3
    • Carefully disconnect the connector wire on the bottom left edge of the circuit board using a plastic opener tool.
    • Move apart the connector to expose the fourth screw.
  11. Pebble Time Circuit Board Replacement: paso 11, imagen 1 de 1
    • Remove the final screw from the circuit board with a J000 Philips head screwdriver.
  12. Pebble Time Circuit Board Replacement: paso 12, imagen 1 de 2 Pebble Time Circuit Board Replacement: paso 12, imagen 2 de 2
    • Turn the watch to the side and use the plastic opening tool to lift up the circuit board.
    • Remove the circuit board from the case.
Conclusión
Nicolas Hempe
Miembro Desde 02/15/17
1,468 Reputación
5 Guías creadas
Equipo
USF Tampa, Team 1-3, Sullivan Spring 2017 Miembro de USF Tampa, Team 1-3, Sullivan Spring 2017
USFT-SULLIVAN-S17S1G3
Miembros de 4
10 Guías creadas
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 8
Todo El Tiempo: 1,007
