Saltar al contenido principal
Patch your Patagonia Nano Puff ® Jacket with Repair Tape
Qué necesitas
  1. Patch your Patagonia Nano Puff ® Jacket with Repair Tape, Patch your Patagonia Nano Puff ® Jacket with Repair Tape: paso 1, imagen 1 de 1
    • Inspect the damage on your jacket. Clip any dangling threads or fabric using small scissors.
  2. Patch your Patagonia Nano Puff ® Jacket with Repair Tape: paso 2, imagen 1 de 3 Patch your Patagonia Nano Puff ® Jacket with Repair Tape: paso 2, imagen 2 de 3 Patch your Patagonia Nano Puff ® Jacket with Repair Tape: paso 2, imagen 3 de 3
    • Grab your repair tape.
    • Flip the repair tape to the back side.
    • Using a permanent marker, draw an oval slightly larger than the hole.
    • If you have a wide hole, you can use a rectangle, but be sure to round the edges. Rounding the edges prevents the corners from getting caught and peeling up.
  3. Patch your Patagonia Nano Puff ® Jacket with Repair Tape: paso 3, imagen 1 de 2 Patch your Patagonia Nano Puff ® Jacket with Repair Tape: paso 3, imagen 2 de 2
    • Cut out your shape using scissors.
  4. Patch your Patagonia Nano Puff ® Jacket with Repair Tape: paso 4, imagen 1 de 3 Patch your Patagonia Nano Puff ® Jacket with Repair Tape: paso 4, imagen 2 de 3 Patch your Patagonia Nano Puff ® Jacket with Repair Tape: paso 4, imagen 3 de 3
    • Using your fingernail, or a pin, peel the backing off the tenacious tape, so that you only have the clear sticky layer.
    • Be sure not to touch the sticky side of the tape as this will gum up the tape and it won’t stick well.
  5. Patch your Patagonia Nano Puff ® Jacket with Repair Tape: paso 5, imagen 1 de 2 Patch your Patagonia Nano Puff ® Jacket with Repair Tape: paso 5, imagen 2 de 2
    • Lay the tape over the hole and press the tape down with your finger.
  6. Patch your Patagonia Nano Puff ® Jacket with Repair Tape: paso 6, imagen 1 de 2 Patch your Patagonia Nano Puff ® Jacket with Repair Tape: paso 6, imagen 2 de 2
    • Use a fingernail or spudger to work out all of the air bubbles under the tape. Continue rubbing the tape until it is well-adhered.
Linea de Meta
9 personas más completaron esta guía.
Brittany McCrigler
Miembro Desde 03/05/12
88,605 Reputación
132 Guías creadas
Equipo
iFixit Miembro de iFixit
Community
136 Miembros
15,126 Guías creadas
2 comentarios
I followed this tutorial and used Tenacious tape by Gear Aid because it claims to not leave a residue behind if removed. That was a bad idea. I am now ready to upgrade this patch to a sewn one and removing the tape is absolutely leaving behind a residue. Really annoyed right now.
Ling Wang - Contestar
This is really helpful, thanks.
James
James Riley - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 8
Ultimos 7 días: 34
Ultimos 30 días: 94
Todo El Tiempo: 43,436
