Saltar al contenido principal
Parrot Skycontroller 2 Battery Replacement
Qué necesitas
  1. Parrot Skycontroller 2 Battery Replacement, Battery: paso 1, imagen 1 de 3 Parrot Skycontroller 2 Battery Replacement, Battery: paso 1, imagen 2 de 3 Parrot Skycontroller 2 Battery Replacement, Battery: paso 1, imagen 3 de 3
    • Flip your controller face down.
  2. Parrot Skycontroller 2 Battery Replacement: paso 2, imagen 1 de 1
    • Remove one 9mm screw using a #4 flathead screwdriver.
  3. Parrot Skycontroller 2 Battery Replacement: paso 3, imagen 1 de 3 Parrot Skycontroller 2 Battery Replacement: paso 3, imagen 2 de 3 Parrot Skycontroller 2 Battery Replacement: paso 3, imagen 3 de 3
    • Insert the plastic opening tool into the top of the cover and pry upwards to lift the battery cover.
    • Remove the cover by pulling up and out.
  4. Parrot Skycontroller 2 Battery Replacement: paso 4, imagen 1 de 3 Parrot Skycontroller 2 Battery Replacement: paso 4, imagen 2 de 3 Parrot Skycontroller 2 Battery Replacement: paso 4, imagen 3 de 3
    • Pull the connectors out by gently pushing the tabs and pulling up on the connector.
    • Disconnect the battery from the remote by pressing the white tab and pulling the connectors apart.
  5. Parrot Skycontroller 2 Battery Replacement: paso 5, imagen 1 de 2 Parrot Skycontroller 2 Battery Replacement: paso 5, imagen 2 de 2
    • Remove the battery from its brackets by pulling up on the ends of the battery.
Conclusión
Una persona más ha completado esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 4
Ultimos 7 días: 10
Ultimos 30 días: 54
Todo El Tiempo: 2,397
