Introducción
If you will be working on your Skycontroller 2, it is imperative that you remove the battery at the start. Also, if your Skycontroller 2 is not powering on or holding a charge, it is necessary to replace the battery. To replace the battery, use this guide.
Before beginning, make sure to power off your device completely and disconnect from any external power source.
Qué necesitas
Una persona más ha completado esta guía.
