Saltar al contenido principal
Parrot Mambo (PF727001) Motor Replacement
Qué necesitas
  1. Parrot Mambo (PF727001) Motor Replacement, Defective Motor: paso 1, imagen 1 de 3 Parrot Mambo (PF727001) Motor Replacement, Defective Motor: paso 1, imagen 2 de 3 Parrot Mambo (PF727001) Motor Replacement, Defective Motor: paso 1, imagen 3 de 3
    • This motor is the defective one. The motor shaft is allowed to move freely up and down. Mine was the front right motor.
  2. Parrot Mambo (PF727001) Motor Replacement, Remove Rubber Foot: paso 2, imagen 1 de 3 Parrot Mambo (PF727001) Motor Replacement, Remove Rubber Foot: paso 2, imagen 2 de 3 Parrot Mambo (PF727001) Motor Replacement, Remove Rubber Foot: paso 2, imagen 3 de 3
    • Flip quadcopter over to its underside
    • Use spudger or your fingernail to get underneath the rubber foot.
    • Remove rubber foot
  3. Parrot Mambo (PF727001) Motor Replacement, Remove Electronics Housing: paso 3, imagen 1 de 2 Parrot Mambo (PF727001) Motor Replacement, Remove Electronics Housing: paso 3, imagen 2 de 2
    • Use the T4 driver to remove 4 screws.
    • Gently lift up the panel starting from the rear of the quad, and unhooking from the lip on the front.
  4. Parrot Mambo (PF727001) Motor Replacement, Disconnect Motor Wires: paso 4, imagen 1 de 3 Parrot Mambo (PF727001) Motor Replacement, Disconnect Motor Wires: paso 4, imagen 2 de 3 Parrot Mambo (PF727001) Motor Replacement, Disconnect Motor Wires: paso 4, imagen 3 de 3
    • You will now disconnect the motor wires that correspond to the motor you are replacing. I had to disconnect the rear right in order to correctly rewire the front right motor.
    • Pull gently on the wire and use the spudger to pop the connector out of its socket
    • Pull wires free from board
  5. Parrot Mambo (PF727001) Motor Replacement, Motor Removal: paso 5, imagen 1 de 3 Parrot Mambo (PF727001) Motor Replacement, Motor Removal: paso 5, imagen 2 de 3 Parrot Mambo (PF727001) Motor Replacement, Motor Removal: paso 5, imagen 3 de 3
    • Grasp the motor you want to remove in one hand and the frame in the other and pull firmly to pull the motor out.
    • My motor did not work because the contacts were broken in the crash. Thus, the motor separated from its contacts.
  6. Parrot Mambo (PF727001) Motor Replacement: paso 6, imagen 1 de 3 Parrot Mambo (PF727001) Motor Replacement: paso 6, imagen 2 de 3 Parrot Mambo (PF727001) Motor Replacement: paso 6, imagen 3 de 3
    • Use the spudger to remove the base of the motor by pushing it through the top.
Conclusión
10 personas más completaron esta guía.
JJ Burrill
Miembro Desde 09/14/16
403 Reputación
1 Guía escrita
6 comentarios
Actually, a T3 Torx driver / bit is needed, not a T4.
Yes, that is very small.
Robert Knows - Contestar
I can’t seem to open up the back side using the T3’s. I have the exact same model but the screws won’t budge for some reason. Any suggestions?
Faizan - Contestar
Quick Question are the 2 back motors consider motor. “C” ?? Thanks Appericate this
Alejandro Padilla - Contestar
Motor C is front left and rear right
Richard Nelson - Contestar
i crashed my drone into a tree and the motor wires got stuffed this helped alot
Nick - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 13
Ultimos 30 días: 45
Todo El Tiempo: 9,647
