Saltar al contenido principal
Parrot Hydrofoil Orak Propellers Replacement
  1. Parrot Hydrofoil Orak Propellers Replacement, Propellers: paso 1, imagen 1 de 3 Parrot Hydrofoil Orak Propellers Replacement, Propellers: paso 1, imagen 2 de 3 Parrot Hydrofoil Orak Propellers Replacement, Propellers: paso 1, imagen 3 de 3
    • Locate the propellers of the same angle, each diagonally across from each other.
    • Locate the propellers of the opposite angle, located diagonally across from each other.
    • Grip each white propeller firmly and pull up to remove.
    • Removing the propellers may require a decent use of force.
    • When replacing the propellers make sure to place the corresponding set in the right position, diagonally across from each other to ensure proper liftoff.
Conclusión
Jacob Munson
Miembro Desde 10/06/16
200 Reputación
1 Guía escrita
Equipo
Cal Poly, Team 20-2, Livingston Fall 2016 Miembro de Cal Poly, Team 20-2, Livingston Fall 2016
CPSU-LIVINGSTON-F16S20G2
4 Miembros
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 5
Ultimos 30 días: 11
Todo El Tiempo: 736
