Saltar al contenido principal
Parrot FLYPAD Joystick Replacement
Qué necesitas
  1. Parrot FLYPAD Joystick Replacement, Joystick: paso 1, imagen 1 de 1
    Herramienta utilizada en este paso:
    Magnetic Project Mat
    $19.95
    Comprar
    • Total of 6 Screws are located in the back of the controller.
    • Four 0.9mm T6 screws
    • Two 0.1mm T6 screws
    • Flip the Flypad over.
    • Remove the six screws using a T6 screwdriver.
    • Use a Magnetic Mat to prevent loss of screws. Set aside.
  2. Parrot FLYPAD Joystick Replacement: paso 2, imagen 1 de 1
    • Flip the Flypad over again and separate the front and back. Be sure to remove the foam adhesive that connects the front plate to the motherboard.
    • Be aware that the Buttons (L1,R1) may fall out. Remember to put them back in place during reassembly.
    • Use Ph0 tool to remove the screws holding the motherboard in place.
    • Gently remove the motherboard from the front plate.
  3. Parrot FLYPAD Joystick Replacement: paso 3, imagen 1 de 2 Parrot FLYPAD Joystick Replacement: paso 3, imagen 2 de 2
    • Pop the joysticks out by pulling gently.
  4. Parrot FLYPAD Joystick Replacement: paso 4, imagen 1 de 1
    • Unscrew and replace joystick caps for a more comfortable grip.
Conclusión
HUY NGUYEN
Miembro Desde 04/10/17
376 Reputación
3 Guías creadas
Equipo
UW Tacoma, Team S3-G5, Liner Spring 2017 Miembro de UW Tacoma, Team S3-G5, Liner Spring 2017
UWT-LINER-S17S3G5
5 Miembros
3 Guías creadas
2 comentarios
Do you know where I can find replacement joystick caps like the one shown in Step 4, please?
cbeilstein - Contestar
Same question as above regarding joystick caps please
Alex - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 10
Todo El Tiempo: 694
