Saltar al contenido principal
Parrot FLYPAD Buttons Replacement
Qué necesitas
  1. Parrot FLYPAD Buttons Replacement, Buttons: paso 1, imagen 1 de 2 Parrot FLYPAD Buttons Replacement, Buttons: paso 1, imagen 2 de 2
    • Position the controller so the back is facing up.
    • Use a T6 screwdriver to remove the six screws on the back of the controller: four 0.9 mm screws and two 0.1 mm screws.
  2. Parrot FLYPAD Buttons Replacement: paso 2, imagen 1 de 2 Parrot FLYPAD Buttons Replacement: paso 2, imagen 2 de 2
    • Remove the foam adhesive that connects the front plate to the motherboard
    • The buttons (L1,R1) may fall out. Set aside to replace during reassembly.
    • Use a Phillips #0 screwdriver to remove the two 0.7 mm screws.
    • Remove the motherboard from the front plate.
  3. Parrot FLYPAD Buttons Replacement: paso 3, imagen 1 de 3 Parrot FLYPAD Buttons Replacement: paso 3, imagen 2 de 3 Parrot FLYPAD Buttons Replacement: paso 3, imagen 3 de 3
    • Remove the buttons from the front plate of the fly pad and replace as needed.
    • Hold the front plate of the fly pad facing downwards to prevent buttons from falling out.
    • Make sure the text on buttons L1 and R1 correctly line up with L2 and R2 when reassembling the device.
Conclusión
2 personas más completaron esta guía.
HUY NGUYEN
Miembro Desde 04/10/17
376 Reputación
3 Guías creadas
Equipo
UW Tacoma, Team S3-G5, Liner Spring 2017 Miembro de UW Tacoma, Team S3-G5, Liner Spring 2017
UWT-LINER-S17S3G5
5 Miembros
3 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 1
Todo El Tiempo: 542
