Saltar al contenido principal
Parrot Bebop Drone Styrofoam Nose Replacement
Qué necesitas
  1. Parrot Bebop Drone Styrofoam Nose Replacement, Battery: paso 1, imagen 1 de 2 Parrot Bebop Drone Styrofoam Nose Replacement, Battery: paso 1, imagen 2 de 2
    • Begin by removing the velcro strap around the battery.
  2. Parrot Bebop Drone Styrofoam Nose Replacement: paso 2, imagen 1 de 2 Parrot Bebop Drone Styrofoam Nose Replacement: paso 2, imagen 2 de 2
    • While holding onto the nose, gently pull the battery away from the nose.
  3. Parrot Bebop Drone Styrofoam Nose Replacement: paso 3, imagen 1 de 3 Parrot Bebop Drone Styrofoam Nose Replacement: paso 3, imagen 2 de 3 Parrot Bebop Drone Styrofoam Nose Replacement: paso 3, imagen 3 de 3
    • Once the battery is separated from the nose, push down on the connector and pull the battery away from the connector.
  4. Parrot Bebop Drone Styrofoam Nose Replacement, Styrofoam Nose: paso 4, imagen 1 de 2 Parrot Bebop Drone Styrofoam Nose Replacement, Styrofoam Nose: paso 4, imagen 2 de 2
    • Remove the two 7mm T5 torx screws using a screwdriver. There is one located on each side.
  5. Parrot Bebop Drone Styrofoam Nose Replacement: paso 5, imagen 1 de 1
    • Take the metal spudger, to remove the double stick tape from the foam.
  6. Parrot Bebop Drone Styrofoam Nose Replacement: paso 6, imagen 1 de 1
    • Remove the styrofoam nose from over the drone's camera by sliding it towards the front of the drone at an angle.
Conclusión
To reassemble your device, follow these intructions in reverse order
2 personas más completaron esta guía.
Equipo
UW Tacoma, Team 1-3, Rose Winter 2017 Miembro de UW Tacoma, Team 1-3, Rose Winter 2017
UWT-ROSE-W17S1G3
4 Miembros
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 14
Todo El Tiempo: 913
