Introducción
The keypad of Pantech Matrix C740 functions as the mechanism for dialing numbers and typing on the device ; however, faulty functioning of the keypad may cause the device to not dial numbers or type words. Therefore, this guide serves as an aid in the replacement of the keypad for the Pantech Matrix C740.
Herramientas
Partes
No se especificaron partes.
Gently slide the backside phone cover off exposing the battery underneath.
Use a Phillips screwdriver to remove the four 2mm Phillips #000 screws from each corner of the device.
Rotate the phone so the base is facing you.
Use spudger to separate phone casing and inside as shown.
Remove the casing carefully and set aside.
Place phone with exposed motherboard facing you.
Use a Phillips screwdriver to remove the five 2mm Phillips #000 screws holding the camera in place.
