Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
Pantech Matrix Camera Button Replacement
Qué necesitas
  1. Pantech Matrix Camera Button Replacement, Phone Orientation: paso 1, imagen 1 de 1
    • Place phone with screen side facing toward you.
    Pregunta a FixBot
    Agregar Comentario
  2. Pantech Matrix Camera Button Replacement, Phone Orientation: paso 2, imagen 1 de 1
    • Flip phone over so screen side is now facing down.
    Pregunta a FixBot
    Agregar Comentario
  3. Pantech Matrix Camera Button Replacement, Remove Back Cover: paso 3, imagen 1 de 2 Pantech Matrix Camera Button Replacement, Remove Back Cover: paso 3, imagen 2 de 2
    • Gently slide the backside phone cover off exposing the battery underneath.
    Pregunta a FixBot
    Agregar Comentario
  4. Pantech Matrix Camera Button Replacement, Lift Battery: paso 4, imagen 1 de 1
    • Carefully lift the battery up from where the spudger is pointed.
    Pregunta a FixBot
    Agregar Comentario
  5. Pantech Matrix Camera Button Replacement, Remove Battery: paso 5, imagen 1 de 1
    • Remove the battery from its dock.
    Pregunta a FixBot
    Agregar Comentario
  6. Pantech Matrix Camera Button Replacement, Slide SIM Card Out: paso 6, imagen 1 de 3 Pantech Matrix Camera Button Replacement, Slide SIM Card Out: paso 6, imagen 2 de 3 Pantech Matrix Camera Button Replacement, Slide SIM Card Out: paso 6, imagen 3 de 3
    • Slide the SIM Card out of its dock.
    Pregunta a FixBot
    Agregar Comentario
  7. Pantech Matrix Camera Button Replacement, Remove Phone Screws: paso 7, imagen 1 de 2 Pantech Matrix Camera Button Replacement, Remove Phone Screws: paso 7, imagen 2 de 2
    • Use a Phillips screwdriver to remove the four 2mm Phillips #000 screws from each corner of the device.
    Pregunta a FixBot
    Agregar Comentario
  8. Pantech Matrix Camera Button Replacement, Identify and Remove Phone Casing: paso 8, imagen 1 de 2 Pantech Matrix Camera Button Replacement, Identify and Remove Phone Casing: paso 8, imagen 2 de 2
    • Rotate the phone so the base is facing you.
    • Use spudger to separate phone casing and inside as shown.
    • Remove the casing carefully and set aside.
    Pregunta a FixBot
    Agregar Comentario
  9. Pantech Matrix Camera Button Replacement, Remove Camera Screws: paso 9, imagen 1 de 2 Pantech Matrix Camera Button Replacement, Remove Camera Screws: paso 9, imagen 2 de 2
    • Place phone with exposed motherboard facing you.
    • Use a Phillips screwdriver to remove the five 2mm Phillips #000 screws holding the camera in place.
    Pregunta a FixBot
    Agregar Comentario
  10. Pantech Matrix Camera Button Replacement, Identify and Remove Camera Button: paso 10, imagen 1 de 2 Pantech Matrix Camera Button Replacement, Identify and Remove Camera Button: paso 10, imagen 2 de 2
    • Carefully remove the motherboard to expose the camera button.
    • Grasp the camera button with a polypus and pull gently to remove the camera button.
    Pregunta a FixBot
    Agregar Comentario
Conclusión
Una persona más ha completado esta guía.
Zeel Patel
Miembro Desde 10/13/14
1,096 Reputación
9 Guías creadas
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 5
Ultimos 30 días: 30
Todo El Tiempo: 381
