Saltar al contenido principal
Pantech Matrix Battery Replacement
Qué necesitas
  1. Pantech Matrix Battery Replacement, Phone Orientation: paso 1, imagen 1 de 1
    • Place phone with screen side facing toward you.
  2. Pantech Matrix Battery Replacement, Phone Orientation: paso 2, imagen 1 de 1
    • Flip phone over so screen side is now facing down.
  3. Pantech Matrix Battery Replacement, Remove Back Cover: paso 3, imagen 1 de 2 Pantech Matrix Battery Replacement, Remove Back Cover: paso 3, imagen 2 de 2
    • Gently slide the backside phone cover off exposing the battery underneath.
  4. Pantech Matrix Battery Replacement, Lift Battery: paso 4, imagen 1 de 1
    • Carefully lift the battery up from where the spudger is pointed.
  5. Pantech Matrix Battery Replacement, Remove Battery: paso 5, imagen 1 de 1
    • Remove the battery from its dock.
Conclusión
Zeel Patel
Miembro Desde 10/13/14
1,078 Reputación
9 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 3
Todo El Tiempo: 255
