Saltar al contenido principal
Pantech CDM8975 Screen Replacement
Qué necesitas
  1. Pantech CDM8975 Screen Replacement, Screen: paso 1, imagen 1 de 1
    • Open flip phone so that the screen and keyboard are facing you in order to access the screws.
  2. Pantech CDM8975 Screen Replacement: paso 2, imagen 1 de 1
    • Remove the four screws. (Four corners of the screen) Note: Make sure you have a safe spot to place the screws.
  3. Pantech CDM8975 Screen Replacement: paso 3, imagen 1 de 2 Pantech CDM8975 Screen Replacement: paso 3, imagen 2 de 2
    • Once the screws are removed, use a spudger to separate the back shield from the top half of the phone.
    • Warning: remove the battery prior to removing the screen
  4. Pantech CDM8975 Screen Replacement: paso 4, imagen 1 de 1
    • Set the phone down with the exposed side facing up.
  5. Pantech CDM8975 Screen Replacement: paso 5, imagen 1 de 1
    • Near the hinge of the phone there is a green circuit board.
    • On the underside of the board, there is an orange plastic connector that connects the battery to the screen.
    • The LCD screen is the metal square with the black LCD screen in the middle. This should not be confused with the clear plastic protective screen on the front of the phone. The LCD screen is displayed here with a blue arrow.
    • Pull the LCD screen out with your fingers and disconnect the circuit board from the orange plastic piece with the spudger.
  6. Pantech CDM8975 Screen Replacement: paso 6, imagen 1 de 1
    • Note: If your replacement LCD screen came with microphone, speakers, etc. attached by wires already, simply remove the existing LCD, microphone, etc. (since they are already attached) and you will not need to perform any of the cutting or soldering steps. You can simply insert the new screen and accessories, and close up the phone.
    • Note: If your replacement LCD screen did not come with microphone, speakers, etc. attached, then continue the guide as written.
    • Using scissors, disconnect the speaker from the phone.
    • Note: all steps involving scissors and soldering are not displayed in this guide or have already been performed in the pictures. Your phone will look different from these pictures, since the cutting steps have not been performed. Follow the steps in the guide for true instructions - pictures are only to help illustrate locations of steps.
  7. Pantech CDM8975 Screen Replacement: paso 7, imagen 1 de 1
    • Pull the wires from the screen which connect to the speaker carefully.
  8. Pantech CDM8975 Screen Replacement: paso 8, imagen 1 de 2 Pantech CDM8975 Screen Replacement: paso 8, imagen 2 de 2
    • Carefully remove the screen. Leave the wires from the speakers exposed (top of the phone).
  9. Pantech CDM8975 Screen Replacement: paso 9, imagen 1 de 2 Pantech CDM8975 Screen Replacement: paso 9, imagen 2 de 2
    • Make sure all of the wires are out of the way before inserting new screen.
  10. Pantech CDM8975 Screen Replacement: paso 10, imagen 1 de 1
    • Put the new screen into the phone.
    • Solder wires into screen if necessary.
  11. Pantech CDM8975 Screen Replacement: paso 12, imagen 1 de 1
    • Re-attach the backing of the phone with the four screws.
    • Your phone should now be operational (after reinserting the battery). If it is not, revisit the steps, and make sure everything was reassembled correctly.
    • If your phone turns on and displays, you are finished!
Linea de Meta
Chris
Miembro Desde 02/13/14
1 Reputación
1 Guía escrita
Equipo
Ohio State, Team 1-4, Meza Spring 2014 Miembro de Ohio State, Team 1-4, Meza Spring 2014
OSU-MEZA-S14S1G4
4 Miembros
4 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 9
Todo El Tiempo: 430
